Need new tires (recommendations/advice)
ok so i put on some used rims with used tires and found out my front 2 tires have leaks. The have about 85% life left.
Details: current tires on are Nankang NSII (cheap i know )
they are low pros if that is the correct term.
i believe they are summer tires (correct?)
my rims are 18x8+50
i plan on putting all season tires on.
what tires would anyone here recommend to fit onto these rims? should i just change out two and leave the rears alone? i have never heard of 2 front allseasons and 2 rear summers (probably for good/safety reasons).
Or should i get a different brand of summer tires (if the current ones i have are summers) for the front?
FYI: im a typical poor college student so im looking for the best bang for my buck. im not into racing so im looking for a good, safe and reliable tire.
my rims are 18x8+50
But, OP, if your front tires are able to be repaired I would look into that. I don't see the point in buying new tires if you can get your current ones repaired and they have a lot of tread left.
If you do decide to get new tires I HIGHLY recommend the Continental DWS's. I'm running a 245/45R17 set and they are phenomenal.
CostcoFanAUS
09-18-2015 06:05 AM
