NEED HELP!!! Tire and Suspension Specialist
KICKED IN THE BALLS
Hey guys like the title says I need some advice on tires for my car.
Here is scoop my car is running on H&R race springs with tokico shocks. I have a set of rims that I want to put on my car but I am not sure if there will be any rubbing with certain tire width.
I have a set of 19" Axis Pentas with a 35 offset. Am I going to be able to run 245/35 on my car or should I go down to 235/35.
Thanks guys.
Thanks guys.
KICKED IN THE BALLS
These axis came off of a acura tl as wheel if that helps at all.
I ran the exact wheel spec; 19x8.5 +35ET with 245/35R19 Dunlop DZ101 and I got 0 rubbing, except on the rear A-spec body kit that quickly went away.
I have Toyo T1-R on my M3 and I think they're not that small. I'm pretty sure they're larger than Falkens, so they MIGHT rub.
KICKED IN THE BALLS
KICKED IN THE BALLS
I do not of a BBK on it so I am glad I don't have to use spacers. I def will take pics once they are on. If they rub then I will sell them to you :p
KICKED IN THE BALLS
What do you guys recommend. I am thinking about getting anodized blue ones.
1fatcrxnem1
22
06-01-2018 01:23 AM
