Need help with Rims/Tires
Im looking for some 18" Rims for my 2003 tl. I need help cause i have no clue what any of these numbers mean.. the off sets, The numbers on the tires.. I dont want any rubbing and i cant do anything to the body because its a lease. If someone could please help me out and let me know what a good combo of rim and tire size so i wont get any rubbing... Thanks
for 18's you should look for rims that are 18x7.5 with a +45 offset... the higher the better.... and for tires you should go with 225/40/18 or 225/45/18... the 45 has more tires and protect the rim a little more but will most likely rub more then the 40 series...
check here for the explaination of offset:offset
For the rest, look here:
definitions
If you want an 18" wheel, I'd look for a minimum +48 or higher offset. With a +45, you might be looking at minor trimming in the rear. A 225/40/18 with a 18x7.5", +50 offset wheel will work nicely for you.
definitions
4th Gear
With the 18's on a TL, on tight turns do the tires hit the inner wheel well? Im also looking for rims for my TL but its not a lease, so i wanna do some body work also. Im from Jersey, and if you ever feel like taking a ride, theres a place called Action Tire on Route 46 in Lodi NJ. It should take you like a hour and a half-they know their stuff there man. maybe they could help you out
Moderator Alumnus
Originally posted by Pimpin_TL
hey guys, what about
Front: 8x18 +38 offset and Rear 9x18 +45 offset PCD/114.3x5
tires: Front:225/45/18 Rear:255/35/18
will this work and still be comfortable?
thanx
thanx
slimmyjimmy
09-26-2006 02:52 PM
