Need help on an aggressive look
im tryna put some wheels on my tl type s i have some ideas but need help on how i to make it look aggressive. 18 x8 +46. Or
18 x 9.5 +35 with a 2" drop. What tiers would anyone recomond.. fender roll? And do i need spacers in the front so the breaks dont rub..? If so what mm should i use.. please help.
let me get this straight.....
you want the most aggressive set up; yet you're playing with the idea of 18x8 +46?
that's like stock specs.
where do you get these numbers from?
this is a hard question because NOT EVERY ONE has the same set up.
yes, there are very similar set ups but i guarantee yours will be unique.
as is my car, because we arent dropped the same height.
it solely depends on how low you are.
Do you want to stretch tires?
do you like a beefy tire?
2014 Jeep SRT
You want to stretch tires on an 8" wide wheel? You done lost your mind....
Look in the XXR 530 thread. There are tons of different wheel/tire/suspension combos in there. It will give you a good idea of what kind of specs you want.
MrHeeltoe
20
02-23-2023 01:54 PM
DerrickW
11-15-2015 05:52 PM
MrHeeltoe
09-29-2015 10:43 PM
MrHeeltoe
09-28-2015 05:43 PM
