need an alignment shop in NY
i'm in need of a good alignment shop in ny...all four of my tires are gone in less then 18 months...they were toyo proxes 4...both the inner and outer threads are almost bald...the car is dropped with tein spings...but unaware of the amount dropped...but i've seen you done need a camber kit with the tl..so i'm wonderin if you guys kno some1 thats good in the ny area...thanks for your help...
Retired!!! ON TOP!!!
It's the TOE that's affecting the threads... basically, any alignment shop can do your alignment properly. I would suggest you go to several places and see if they are using the modern machine with the lazers.
Remember, everytime you change the height of a vehicle, it's recommended to get an alignment check because the change in height modifies the averall geometry of the suspension.
PS: I would reccomend a Camber Kit... So you wouldn't have this problem again.
emailnatec
29
09-28-2018 04:27 PM
DerrickW
11-15-2015 05:52 PM
