My new wheels!
My new wheels!
Hi guys,
I just picked up a set of these yesterday:
![](http://www.sonictuning.com//media/catalog/product/cache/1/small_image/150x150/5e06319eda06f020e43594a9c230972d/s/t/st100-2_2_2_1.jpg)
18x8.5 ST100 ET48 ( yea they're CH reps
I'll be putting them on my TL-s with 215/40/18 hankook v12's with 25mm spacers. Hopefully will be able to go lower as well since i have a reduced sidewall now. Just wanted to say thanks to Azine since I always frequent the forums but don't have many posts! Pics will be up once mounted
![Yum](https://acurazine.com/forums/images/smilies/yum.gif)
![](http://farm5.static.flickr.com/4094/4825598509_95dcaebc37_z.jpg)
Hmn... Don't look that much different from your stockies now. But I'm sure it will look pimp once you've mounted them on seeing as how you're already dropped too. What are you dropped on? Coilovers? Springs? Brand?
id say run the 35 offset and drop the spacers if anything maybe a 5mm spacer if u can choose your offsets get the right one and skip the spacers and sell them on ebay or something
I like the stretched tire look. Looks high tech and sporty and due to the angle of the side wall, it sure can't fold over! So its gotta be great for performance.. But I suspect that it may be a firmer ride also. Because tires actually do absorb shock. It fluctuates based on side wall strength and tire height and probably also the geometrics of the physical shape of the side wall. ie. bubbled out(lots of shock absorbtion) or slanted inward(reduce shock absorbtion) =)
offset question
I have a quick question, although I know that this thread is a little old...i'm considering getting these same wheels and I just want to understand why everyone says that the +48 offset will never work.
I hit up an offset calculator online and according to it, the difference between my stock 8" wheel w/ a +45 offset and this 8.5" wheel w/ a +48 offset means that the ouside edge of the wheel will EXTEND out an extra 3mm and that it will give me 9mm less clearance on the inside. So my question is??? why does everyone say it will never work? is it becuase of the 9mm less clearance inside because if it extends 3mm further out, that is surely no big deal at all. In fact, if they stick out 3mm further than the oem rims, then perhaps it might not even look bad?
Also, Jay did you say that they also had +35mm in stock for our bolt pattern? That would be perfect for me since I havent bought spacers like you already had...
-asmcbride
-asmcbride
to ASMCBRIDE, its because he has a type-s, and the brembo caliper makes you need a lower offset. +48 works fine on a base but still looks funny because they are so sucken in. I currently run a 35 offset on my base and there is no rub
Received 6,470 Likes
Please post some closer, clearer pics.
but the offset calculator says that they will extend 3mm farther than the stock wheels...I dont thinkg the stock wheels look horrible/funny...although, its not lowered either...is it because it would look funny lowered with this type of offset? perhaps I need to see a picture of a lowered base TL w/ stock wheels or at least an offset that would match the stock wheels (17" +45)
Cheers
JByron
01-08-2016 09:49 PM
