Mismatched Tire Sizes
Chapter Leader (Central Florida)
OK so after installing my lowering springs this week I have come to the conclusion that my rear tires need to be replaced BADLY (seeing as the inside edges are worn to the belt). I have been considering upsizing to 255/40R17 for a bit but seeing as I need rear tires immediately, would putting 255/40R17's on the back and leaving the 235/45R17's on the front cause any problems? Im not too concerned with small issues since I will replace the fronts in a week or so but I just want to make sure that my VSA wont go nuts or anything like that.
Thanks!
Thanks!
Thanks!
Thanks!
I know someone else chimed in and said the TL would be ok, becuase it's FWD, so VSA wouldn't be affected by this sort of thing, only traction control...
But that's why I say that since it's temporary, you could always turn off the VSA for the time being if the system does give you hiccups...
I wouldn't. VSA and/or ABS could be affected. I supposed you could mitigate VSA concerns by turning it off, but VSA could be a life saver if ever in a severe driving situation. With it turned off, you don't have it available should that type of situation present itself.
I also wouldn't want to take the risk of getting into a situation where a panic stop was required and have a chance of ABS malfunction/inconsistency when you need it most.
FWIW, here's what's on page 220 (at least for 04 TL) of the manual:
Using tires of a different
size or construction can cause the
anti-lock brake and the vehicle
stability assist systems to work
inconsistently.
WARNING
Installing improper tires on your
vehicle can affect handling and
stability. This can cause a crash
in which you can be seriously
hurt or killed.
Always use the size and type of
tires recommended in this
owner’s manual.
http://techinfo.honda.com/rjanisis/p...404O00211B.pdf
inconsistently.
WARNING
hurt or killed.
owner’s manual.
nuldabz
09-03-2015 05:49 PM
Mugen TSX
Eastern Canada
09-01-2015 11:05 PM
