Megan Coilovers Stuck
Ok peeps, need help. One of my coilovers is seized. (The lower portion going into the base) Overloaded it with WD40 for the last 3hrs and NO sucess. Ideas?? HELP!
Get a screw driver and put it on one of the little rivets and hit the other end of the screw driver with a hammer and it should loosen it. Good luck.
2014 Jeep SRT
^I think you're talking about hitting one of the rings, but he's talking about the threaded body that's seized on the lower collar. I'm having the same issue with mine. Haven't had a chance to break mine free. Waiting for warm weather.
OP, WD40 is not going to work, it's just a lubricant. You need something that will cut through the corrosion, like PB Blaster.
chopstix (04-04-2013)
+1 for PB Blaster. Worked great when too loosen up bolts when I did my suspension swap a few years back.
2014 Jeep SRT
I love the way it makes your skin smell, three days after you used it lol
2004 TL SSM w/NAVI
when u free them up lube all of your co's with anti sieze and it wont happen again. learned to use that the hard way.
had to use an air chisel to free my tiens on my cg5, they will never be the same lol
2014 Jeep SRT
^I would only use anti-seize on the threads that will actually have the collar/rings against them. Don't put anti-seize on the unused threads bc dirt will just stick to it like glue.
keep it clean
I ran into the same issue when I purchased a set of used Megan coilovers. Try spraying the PB Blaster on the top thread above the base and let it seep through into the base strut housing. Also, there should be a couple of holes exposing some of the threads that are in the base housing. Lay the coilover on it's side with one of the holes on top, and spray some of the PB Blaster in the hole, so the PB Blaster can seep into the threads too. Repeat the process for every hole. Took me three sessions and a lot of raw determination. Don't give up and good luck.
ebelp (04-06-2013)
Yeah my first attempt with PB was a fail. Strut went 2-0 against me. Unfortunately its still mounted on the car. Do you think the outside temp is playing a part? It's a warm 45 in MN. ( SUCKS AZZ ) I'll keep trying!
keep it clean
Megans are my first experience with coilovers, so I'm not sure how other brands hold up. Also, need to consider the type of roads and weather the coilovers are exposed to. For me, I haven't had any issues since, however, I do clean the threads on my coilovers whenever I take my wheels off the TL. It's a good habit for any coilover.
2014 Jeep SRT
You'll be able to get more leverage on it if it's still mounted to the car vs. off the car. Try just unmounting the coilover assembly at the bottom by removing that bottom bolt, then try to put a screwdriver through the coilover where the bolt was and then turn the screwdriver to break it free. Not sure if there will be enough room under there to do that, but it's worth a shot.
keep it clean
2014 Jeep SRT
+1 with this idea, but I'd like to add that you can use the locking rings to create more leverage too. Loosen two of the locking rings and lock them together a few threads above the base. Then use one of the wrenches to apply leverage in the opposite direction you need to turn the base to break it free. I hope my logic makes sense. Maybe ebelp can confirm my thoughts.
If its the rear coilover, you can try uninstalling it from your car and place a metal rod through the hole that mounts the coilover on the bottom and twisting the metal rod, that way you can get more leverage.
I've had my megan coilovers for over 30K miles and the only problem I had was when I raised the height of my car, after being completely slammed in the rears and 1/4" from being slammed in the front, and now my coilovers squeak when going over small bumps on the road at slow speeds. It seems to be going away as the coilovers are beginning to resettle itself into its new position. Other than that its performs great.
2014 Jeep SRT
I've been referring to the rears...if it's one of the fronts then my idea doesn't really apply since there's no bottom bolt pass-through on the front coilover assemblies.
Its the drivers rear one that is the pain in the azz. As for the weather, MN can suck sometimes. For us folks here that can have -20 degree days, 45 is considered warm. Sucks indeed! I'll keep trying at it. My arms and knuckles need a break
2014 Jeep SRT
Let us know if you end up breaking it loose and how you did it. FWIW, that's the same one that's seized on my car too.
2014 Jeep SRT
Trying warming everything up with a heat gun before you start wrenching on it too...that will probably help some.
2014 Jeep SRT
Just realized how awful my grammar was in that last post haha. I'm definitely going to heat up the lower collar of my coilover when I try to break it free. It can't hurt, just wear gloves. Plus it'll keep you warm in that frozen climate of yours lol.
2014 Jeep SRT
Any luck with this?
2014 Jeep SRT
Nooo! Time to bust out the blow torch!
MrHeeltoe
20
02-23-2023 01:54 PM
MrHeeltoe
09-29-2015 10:43 PM
MrHeeltoe
09-28-2015 05:43 PM
4drviper
09-23-2015 07:42 PM
