Measurement charts?
Measurement charts?
By any chance does anyone have any measurements of the wheel well and fender area for our generation? Hoping to use it as a baseline to see what I can get away with.
I was looking for general measurements from the hub to the fender, from the center of the hub to the inside of the wheel wells.
Sorry to be incessant. Just anxious!
BANNED
pasty it's really not so compicated once you understand the geometry of a TL.
stock wheels are 17x8 +45 offset with a 235/45/17 tire.
the wider/more narrow the wheel, and the lower/higher the offset will determine how it will look once mounted.
what are your goals with wheels? flush to fender? sunken in like stock? do you have aftermarket suspension? what is important to you?
keep it clean
+1 with what Italiano suggested. It can be a lot to take in, but you learn things during your searches that you weren't expecting, and will benefit you with future mod questions. Trust me, that's the way I found this thread. Should answer most of your questions. Good luck.
https://acurazine.com/forums/showthr...errerid=307692
Thank you guys,
I know exactly what look i want after doing plenty of research, and so far what I've come up with is this. I want flushed look?
I know that I want the Work Emotion CR-Kais. I just can't decide if I want the matte gunmetal or the metal buff. The car is Dark Gray, so I'm leaning towards the metal buff to get a little contrast going.
Unfortunately they don't make the wheels I want in 19s, so I have to stay at 18.
I've been contemplating a setup similar to this as of last night.
Wheel Make/Model: Work Emotion Cr-Kai
Wheel Size (**X**): 18x8.5 front 18x9.5 rear
Wheel Offset (+**): 36mm
If lowered (amount): 2in on Tein Basics
transmission (Manual or Auto): Manual
Year/Trim (04-07, Base or Type S): 06 Base
TireSize: 225/40/18 Front 235/40/18 Rear
mlody
12-04-2019 02:11 PM
emailnatec
29
09-28-2018 04:27 PM
