Lowering Question
Lowering Question
I want to lower my 04 TL, The question is can I do a h&r spring combo of 1.4 f & 1.3 R on 19x8.5 rims with a 34 offset with 235/35/19 with out it rubbing. I know many will say do the coil overs but Im just looking to find the wheel well gap. if anybody has a about the same setup please post pics. Thanks Jac
well im taking a chance and bought the H&R sports springs and got in the group buy A-Spec body kit. Hopefully it all works out in the end.
yeah the tires were a lil smaller that what i wanted but it was a package deal already mounted and was a price I could not pass up. I think everything will work out fine and when the tires wear I will do the 245 instead. Thanks Jac
Well have a sort of a problem? I ordered rims about 2 weeks ago. Finally today the rims show up. I was sent a staggert setup,I requested the same size all around but Here's what I got
Front 19x8.5 +34 235/35/19
Rear 19x9.5 +40 265/30/19
I did order the H&R springs and also the A-spec body kits. Hopefully it will all work out and I dont have to send the rims back. If the combo works I will keep them
Any info Please....
Any info Please....
BORICUA
Any info Please....
Any info Please....
Front 20x8.5 +32 245/30/20
Rear 20x10 +40 255/30/20
I didn't have any issues in the front but had to roll the fenders on the back. You will still have 3mm more clearance in the back than I did. If your tires were 255 I'm sure you wouldn't have any problems because 255 would give 13mm more clearance than me and that should be enough. Hope this helps and good luck.
Thanks I appericate it. Im deployed right now and wont be home for another month. Just trying to see if they will work so i dont have to try and treturn them months later. L8er Jac
DiamondJoeQuimby
09-10-2015 11:40 AM
