Loud squeaky front suspension after Tein lowering spring ( WITH VIDEO )
Just installed tein s.tech lowering spring. I have a VERY annoying and loud squeak front suspension. It comes from the driver side.
I shoot the top hat with lithium grease to see if it stop and It did for a 2 days and It started again. I spray more lithium grease on the top hat bushing but the noise is still there, very loud from inside and outside.
Any chance you know what I should do ? try, or change ?
video youtube :
video youtube :
Take the wheel off, support car with jack stands.
Then jack up the lower control arm slowly until you hear where it's squeaking.
No I did not used the jack to raise the fork, everything is tight when I put the strut spring in the fork ( buttom) I used a pry bar to lower everything and fit the new strut spring . I followed this video on youtube.
something easy to check would be the sway bar rubber mounts. Not the end links, but the mounts for the sway bar. Spray them with silicone or something and see if it quits. Something else to consider, If the shock is oem, then maybe the tein is too low for that shock? And the shock could be making noise.. not sure though..
You might want to check the upper arm bolts. DId you loosen the upper arm for any reason? If so,you may want to check them for tightness. And when you tighten those upper arm bolts, make sure you tighten them when the arm is up. Because it will put a bind on the rubber grommet in its natural sitting position. Ultimately, I would tighten the upper arm bolts with the weight of the car on a jack while the tire is off. That should be close to the normal resting position. Either way, they need to be tight so they don't swivel. It sounds like a rubber moving. Also, spray just 1 rubber grommet at a time, and then do the bounce. So you can identify which one is making the noise.
polish_pat
10-28-2015 07:51 AM
10-27-2015 04:44 PM
