Looking for DIY for front subframe removal/front sway at swap
Ok, I searched the garage and the site and I can't seem to find a DIY for a front swaybar swap.
I'm thinking of swapping my base setup with a type S front and rear, but I want to see whether the work of dropping the subframe is worth it.
To drop the sub frame you have to disconnect the high pressure line from your power steering pump,disconnect the sensor on the High pressure line, support the steering wheel with a prop so it doesn't move,remove the bolt the connects your steering column to the rack, pop out the lower ball joints and tie rod ends, remove the bolt that connects the struts to the lower control arm, disconnect the power steering hose from the hard line right by passenger side front sub frame mounting bolt,take the nuts of the lower trans mount studs that go threw the subframe,remove the section of exhaust that connects to all 3 cat converters,remove the 4 bolts that go there the sub frame to told the rear motor mount in, remove the vacuum hose from bottom of front motor mount,remove the bolt that connects the front mount to the bracket bolted to the motor, support the engine/tranny with a engine supporter don't use a jack or jack stands to support it because you won't be able to pull the sub frame out and one you made sure everything is disconnected that attaches to the sub frame support the frame with sum jacks and remove the 4 bolts that hold her in and lower her down.....I'm pretty sure I left a few things out but that's the main concept on dropping the whole subframe lol
08WDPTL (04-22-2014)
Thanks for the reply. It looks like a lot more trouble than it's worth to get a little flatter cornering and based on your description it sounds like I'd need an engine hoist.
Does anyone know if it's possible to just swap out the bushings with PU ones without dropping the subframe?
A guy online removed his front sub-frame completely and did not disconnect the power steering hoses. Instead, he removed the bolts that mount the rack and pinion to the sub-frame and then suspended the rack and pinion with bungee cords. This also kept him from having to disconnect the steering linkage.
marcelft
07-10-2018 06:17 PM
Skirmich
09-15-2015 06:41 PM
