List of Lightweight/Performance Wheels THAT CLEAR BREMBO CALIPERS
Q_ShipTL (03-30-2013)
#43
takin care of Business in
Received 4,732 Likes
^^^ I dont think the DR can be considered light weight...
18x9.5 comes to 22lbs
http://www.evoxforums.com/forums/showthread.php?t=63307
if you compare with say enkei rpf (which is a cast wheel as well)
RPF1 in 17x9 is 16lbs and in 18x9.5 is 17.2 lbs
EDIT:
if you compare to say TC105n 17x9 is 15.8lbs and 18x9.5 is 17.9 lbs
EDIT:
paperboy42190 (09-06-2013)
#48
Rev High; Drive Happy
Just got the NT03s and they are indeed light.
They weigh a slight fraction more than RPF1 at the same spec HOWEVER are much stronger due to design.
18x9.5 +27 = 19.4ish whereas the RPFS will be 18.1ish?
paperboy42190 (09-16-2013)
#50
my friend recently was installing bbk on his civic. wheel was touching the caliper so he started shaving the inside edge of the caliper(close by the hub). after about 2-3mm of shaving, brake fluid started leaking from a pin sized hole that you literally cannot see. needless to say, he abandoned the bbk idea
o4Komodo (09-19-2013)
#51
![Name: temporary_zps4f030c1f.jpg
Size: 114.6 KB](https://acurazine.com/forums/attachments/3g-tl-tires-wheels-suspension-97/48219d1501282511-list-lightweight-performance-wheels-clear-brembo-calipers-temporary_zps4f030c1f.jpg)
#54
If the Enkei NT03 9.5" +27 doesn't fit and shaves the caliper, why is the 9.5" +22 on the list? Did somebody make a boo-boo on the first page of this thread? If you were recommending a 5mm spacer in your thread, should the recommended specs be at least 9.5" +33 or so? Tell me if I've got my offset math off again.
#55
Just checked Enkei's site and the options for 5x114.3 NT03 are below...
17x9.5 +38 20.1 lbs (Hyperblack)
18x7.5 +37 18.5 lbs (F1 Silver)
18x8.5 +38 19.6 lbs (F1 Silver)
18x9.5 +27 19.9 lbs (F1 Silver)
18x9.5 +40 19.4 lbs (F1 Silver)
18x10.5 +30 21.0 lbs (F1 Silver)
http://www.enkei.com/size_chart/NT03.pdf
I'd like to see somebody running a staggered set of 18x9.5 +40 & 18x10.5 +30.
#56
silvrbreez (09-20-2013)
#57
@Paper, how do you like the Type-Fs? I see them on online but they always sell them staggered.. and at the large sizes.. I cant find a good deal for 18's
does NT0318x9.5 +40 clear brembos?
and if you go staggered it will not help perfrmonce... now I dont know if it will hinder but going 18x10.5 on the rears does not sound like it would be good for performance
however that setup will look great if you dropped and -4 cambered
#58
As for the offset with a spacer, I get the +27 with a 5mm spacer is in effect +22, but all that's doing is making your wheel mimick a wheel with a larger distance between the back of the spokes and the hub mounting face.
Without a spacer wouldn't you need a wheel where the mounting surface to the hub is farther towards the face of the wheel in order to clear the Brembos. In that case, wouldn't you want the +33 min offset? To say it another way, if +27 doesn't clear, isn't it pretty much guaranteed that a lower offset won't clear either?
I'm asking. Still trying to sharpen my skills on offsets. It's good to be able to tap into guys like y'all that have gone through a good bit of wheels to learn this kind of stuff.
Here's an image I reference.
![](http://cocomponents.com/dealer/wp-content/uploads/2012/04/ATV-Wheel-Offset-Explaination.jpg)
#59
it truly comes down to the wheel.. the 04-05 OEM wheels is +45 offset.. i think Ville is rocking the rpf1 +45 with 5 mill spacers...
its how the spokes bend outward or away.. or just general clearance of the outward spokes of the wheel
i thought my +38 wheel would fit but I had to get 10mm spacers.. and now I am like 1mm away from the brembo.. I was so pissed when I had the tires swapped... but my mistake.. I should have test fitted first.. it looked like it would fit but the inner side of my spokes is thicker than the outer side of the spokes
#61
I might have some pix in the next couple days
![Wink](https://acurazine.com/forums/images/smilies/wink.gif)
#62
and no, I dont think the 18x9.5 +40 will clear
this thread honestly has some good potential since so many ppl ask about rims all the time, but we need more ppl to contribute and add to the list... this 2nd page no one has copied and pasted the list and added on
#63
ok, I brought it into this page... if i missed anything justupdate it
I know there are some advans people have that should be added...if you following someone who got light weight wheels then please add..
(FYI - I jacked the hell out of the fonts and whatever it is I did to copy and paste)
Acura A-spec wheels 18x8 +45 (~30lbs)
Acura A-spec wheels 18x8.5 +45
Acura TL type-s honeycomb wheels 17x8 +45 (24lbs)
Advan RS 18x9 +22 (18lbs) (Picture)
Enkei NT03 18x9.5 +22
Enkei RPF-01 17x8 +35 (picture)
Enkei RPF-01 17x8.5 +40 (16.0lbs)(picture) (link)
Enkei RPF-01 17x9 +22 (16.75lbs) (picture 12)
Forgestar F14 18x9 +29 (22lbs) (picture)
Forgestar F14 19x8.5 +35
Forgestar F14 19x9 +25 (picture)
Forgestar F14 18x8.5 +33 (19lbs 15.5 oz)
Forgestar F14 18x8.5 +26 (20 lbs 1oz)
MSR Series 045 18x8 +35 (21.9 lbs)
Prodrive GC-05F Monoblock 18x9.5 +22 (18lbs)
Racing Hart CP-035 17x8+38 however needs 10mm spacers (13.9 lbs)
SSR Type F 19x8.5 +42 (19.7 lb)
Volk TE37SL 18x9.5 +22 (18lbs)
Volk TE37/LE37T 19x9.5 +35 (picture)
Volk TE37 19x8 +43
Volk RE30 18x9.5 +35 (picture)
Weds Sport SA-70 17x9 +35 (picture)
Work VS-XX 19x9.5 +28 (picture)
Lightweight but nooffsets so not sure which offset works
Buddy Club P1 Racing QF 17x8 (13.60)
SSR Type-C (called Competitions in the US) 17x8 (14.30)
Motegi Racing Trak Lite 2 17x8 (14.60)
Racing Sparco LE 17x8 (14.60)
5Zigen Beckets FN-01R 17x8 (14.70)
Wed's TC-005 17x8 (14.90)
Wed's TC-105N 17x8 (14.90)
Motegi Racing Trak Lite 17x8 (15.00)
SSR Type-C (called Competitions in the US) 17x8.5 (15.00)
Rules and Legend:
If you are unsure of the weight of the wheel, please highlight theweight in red font and hopefully someone on here who knows the actual weight willcome on here and correct it.
Wheels that do not clear the Brembos will be highlighted inDarkOrchid font. This information will be useful to perspective buyers so thatthey know what size they can not fit.
Also, lets keep this list in alphabetical order in the case that this listbecomes rather large. It will make the information on here a heck-of-a-lot easierto find.
HYPERLINK pictures, don't post photos on the list.
Volk TE37 19x8 +43
Rules and Legend:
#67
^^^ still waiting on shipment....hopefully this weekend
#69
Feji....this seller didnt wanna ship....so I spoke to a Acurazine member who lives in VA (a good friend to all
) to pick up and ship me the wheels...
he wasnt able to get to it last weekend, hopefully I will have some good news this weekend....the seller is not the best with communication....
![Ninja](https://acurazine.com/forums/images/smilies/ninja.gif)
#72
I've decided to go with the same Work Wheels Meister S1R 18x9.5 +20. What I meant to say is would that set up clear the Brembos or would I need to use spacers on my 08 TL-S... The car is lowered on Tein SS. I'm planning to max it as much as I can coming spring. I also got a camber kit which will be installed when I get the wheels.
#73
^^^ dont get me wrong dude but this is not a fitment thread....this is a thread for lightweight wheels....
if you are BENT over the S1R, get the offset you want and work with spacers....I wouldnt decide the offset of a expensive wheel like that...the S1r, IMO, only looks good in a few offsets...so get the wheel you like and add spacers...
NOW if being lightweight was your priority, I would work with offset and say NO to spacers
#76
Th copy paste thing on thos thread is just to complicated on a mobile phone.
But heres my addition:
FITS:
Enkei Kojin 17x9" 45mm around 20lbs
Advanti Racing Deriva 18x9.5" 22mm around 22lbs
Ray's Engineering 57F 18x8.5" 45mm around 17lbs
NOT FIT:
Enkei Nt03s 18x7.5" 37mm around 20lbs (test fitted for the heck of it.)
FITS:
NOT FIT:
#77
Hey I know it's an old post "frowned upon" but I have a UA7 Type S so this thread is what I'm looking for. Was wondering if you know if: Vordoven Forme 1 19x9.5 +22 will fit our cars, and what tires you'd recommend, not going for a stretched rubber band look, I like form and function. It's my daily. Thanks.
#78
![Doh](https://acurazine.com/forums/images/smilies/doh.gif)
#80
i feel like its too obvious but ill say it anyway. all oem wheels from the 3rd gen fit over the brembos.
04-06
07-08
07-08 types
07-08 aspecs (both sizes)
04-06
07-08
07-08 types
