Koni shocks in the front only ?
Old 03-26-2009, 12:25 PM
05 6MT NBP TL
SPEEDYP's Avatar
I am currently running Eiback pro-kit with stock shocks. I like the ride but not the stance there is a big wheel gap in front and almost none in the rear. My solution is to put Koni adjustable shocks. it would drop it by about 15mm which should be alot nicer.
My questions is the following:
Can I just put koni shocks in the front ? will this impact my ride/handling in a negative way ? would that cause any problems down the road ?
Thanks in advance for your advice.
Old 03-26-2009, 12:31 PM
KICKED IN THE BALLS
anarchy[sear]'s Avatar
From what I remember alot of people said there are alot of negative affects when you do this. I forgot who it was but I am sure they will chime in.
Old 03-26-2009, 02:25 PM
AndrewA's Avatar
Seems like it should be ok. You probably want to err on the side of caution and adjust them towards the soft side to match the damping of the rear shocks. Otherwise you may have some strange behavior during hard acceleration and braking.
Old 03-26-2009, 08:06 PM
jjj
jjj's Avatar
Why not just get them all around?
Old 03-26-2009, 09:32 PM
BAT3STL's Avatar
Check this Thread, he got the set up you want to do, for what I hear from him he's very happy with it.
https://acurazine.com/forums/3g-tl-photograph-gallery-96/liking-konis-712795/
Old 03-27-2009, 07:17 AM
05 6MT NBP TL
SPEEDYP's Avatar
I want to buy all 4 but i'm in Canada and its over 1000$ for all 4 which is quite expensive and since the rear sits perfectly no need to put money into it. Just want to eliminate that front wheel gap.
02-25-2020 09:57 AM
jblessing
08-08-2018 09:43 PM
Onyxthecat
10-18-2016 02:05 PM
08 NBP TL
09-08-2015 08:49 PM
sputik
09-07-2015 01:40 PM
Quick Reply: Koni shocks in the front only ?
