jack points - jack stands
Don't have access to my manual - sorry for a dumb question.
Where are the jack points for the car?
Jack stands go?
I have an 07 TL Type "S" with A-spec body kit all around.
Thanks for the help!
Jack stands go?
4 wheels off the ground?
first block wheels on opposite end of car with wood blocks so they cant roll at all
In front is a little bump that sticks down dead center of the car past the radiator
Use a wood block on top of the low profile floor jack and lift there.
jackstands go on the frame rails near where the side jack points are- look for where the door meets the front fender
In back there is a center tie down hook- same trick with the wood block and stands go under the suspension lower mount
If taking the wheels off- loosen the lugs first,, its easier on the ground and you dont rock the car on the stands!!
For extra security when car is on the stands- place the tire on its side under the frame rail- not touching it- but enough that if everything went wrong at once- the car falls on the rim- you slide our with only a scare and a scratch....instead of death
the stock, single wheel lift points, were marked on the lower skirt with a plastic arrow cast into the part- so in front, look at the fender to door area- its double metal overlap right there and it has a cutout in the piece for the cars jack to fit into
IN back its just forward of the tire- agan look for the original cutout on a thin long rail- the fitting on the cars jack mates to that
Use the frame rails when possible for jackstands
navtool.com
31
11-16-2015 08:30 PM
navtool.com
09-25-2015 05:15 PM
