Ingalls or SPC rear camber kit ?
Trying to decide on which camber kit to get. I know the ingalls give toe/camber adjustment. I was just wondering about whether there is a quality difference between the two. Is it really necessary to have the extra toe adjustment of the ingalls ?
Eibach kit. I had the ingalls. The bushing donut over time. not sure about SPC it looks like the Eibach one also. I accidentlt bought 2.. not realizing that one box was enough. So don't trust the generic pictures.
mb.3g (07-07-2016)
Find another shop..never heard u have to make your camber worse...especially that much camber to get the toe right....if u align it every 6k miles or so to keep toe in check u should get more miles out of it...
SPC = same company as Eibach or knock off of Eibach? damn they are 150 also.. Screw that I am glad I got the Eibach. If Eibach can make springs and swap bar I am sure they know how to make camber kit also.
Stock you have toe adjustment , with the SPC type your adding camber adjustment on the top.
Snap_Back4G (08-13-2013)
Former Sponsor
The INGALLS rear kit is a better kit; it gives you toe and camber adjustment for the same price as the Eibach/SPC. By the way, Eibach is just SPC re-branded. We have never had any quality issues on the INGALLS kits and we sell and install a lot of them.
Here is a link to them (you need a qty of 2 if ordering):
http://store.excelerateperformance.c...5/i-60220.aspx
Here are pix from my friends car. He doesn't track and only has tien s techs
Mine were way worst... So OEM arm and eibach ftw in my case
shenrie (05-08-2012)
What did you end up buying? I'm currently shopping for a rear camber kit myself.
jebus, thats some crap. how long have those kits been installed? are those bushings really soft rubber or something? maybe I dont want the ingalls kits after all.
25k. I end up buying the eibach one from the TL and then it didn't fit... So I picked up the ebay jpower one which are the ingall knock off. If they donut again its only 75 bucks instead of 120 for each side from ingalls. Really disappointed but shit happens. Life goes on
why not have bushings made for ingalls stuff? or see if you can find es bushings that will work in the ends. what did you do with ingalls arms??
im having some bushings made for an old ingalls anchor bolt camber kit for up front. still waiting on quote for final price, but Im hoping its not to much.
haha Yea after speaking with danscreations on the phone I gave in and bought the SPC rear upper control arms. And possibly want to buy TLDudes Ingalls rear lower control arms. I'm ordering the skunk2 fronts this week actually.. btw I'm a wo-man lol
HE>i
Anakalia, how much camber you looking to run up front?
I have the camber arms already and they allowed me just enough camber up front. Others have stated that they only got -1.5 camber from them.
I will post back when i get my alignment....I had the original settings at -.5 front camber and -1.5 rear. Just installed 19x9.5 +22 all around and adjusted my camber arms all the way in in the front. Like I said it was "enough" to work. Won't know actual #'s until my alignment though.
I just got the skunk 2 front camber kit, and they are very good. I got them from heeltoe $269, they are on sale go check them out!!!!
MrHeeltoe (10-26-2012)
Former Sponsor
Full article:
http://www.heeltoeauto.com/tech-arti...l-joints..html
Originally Posted by mrheeltoe
I had a customer in today, 05 TSX with some Tein Basics set at a 13.5″ height all around (measured from center of center cap to fender lips). The camber in the rear was corrected with an SPC camber kit, also sold under the CT or Comptech name.
Some of you know from reading our posts and such over the years that we recommend the Ingalls brand of camber kits for the rear on a TSX/TL/CL/Accord. And this post is to tell you why.
Because the arms mentioned, in addition to those sold by Megan Racing and Eibach, all replace the upper arm in the rear to an adjustable part. The rear upper arm that these kits replace on these cars contains a ball-joint to attach it to the rear hub carrier.
The problem with replacing the stock arm with an aftermarket one is that the stock ball-joints have really high quality rubber on the boots, and are deigned to work within a specific range of motion. Because aftermarket ball-joint boots are of inferior material, and are subjected to altered range of motion (when installed on a lowered car), the boots tend to become brittle and they brake after a while.
Full article:
Full article:
I will be keeping my suspension stock. Only adding rear camber kits because of eating tires on the inside. Has anyone experience noise with installing Ingalls rear camber/toe kits on stock suspensions?
I feel pretty comfortable with the last person who done my alignment. The right rear set to 0 toe and camber was -1.8. The left rear is set 0 toe and camber was -1.6. The front was within honda spec. I will go back to dealer to get a copy of alignment spec. and post.
I'm just ready try something else after eating up every tire after oem tire on the inside rear mainly on the right. Did use my local honda dealer where an experience honda tech this trip. No apparent damage or excessive wear to other part of the suspension according to tech.
Still dont have any comments about whether there will any suspension noise because of camber kits installation....
Just want to start off in spec and go from there.
I wont doubt that, but minimal back seat riders. Nothing extra in trucks, maybe 5-10lbs totals except on vacations we took when the car was basically brand new.
Toe is supposed to be 2mm Toe IN according to FSM...
Your toe is off, which is causing excess tire wear, don't think that all tech's know what they are talking about...
Think you should read up some more before spending the loot on camber kits which won't really help your situation....
https://acurazine.com/forums/3g-tl-tires-wheels-suspension-97/alignment-procedures-service-manual-574027/
Not trying to be an ass, but Marcus (Mrheeltoe) is sending you in the right direction, rather than taking your money and laughing...
