I want to lower my 07' TL-S
This is my 1st post. I bought an 07' TL-S in September 07' with 150miles on it and I've only put about 7k on it.
I am interested in lowering my TL-S 1 to 1.5 inches without affecting factory SPECS. So I have been talking to the dealership and a custom auto sports dealer and obviously I want to go with the 3rd party dealer. If I get springs to lower my car do I
A. Need to include the struts?
B. Include a sway bar?
C. Getting a Camber Kit?
I was looking at Eibach Springs because that's prob the most durable brand out there. Anybody know Houston based auto custom dealers.
Bottom line if I get Eibach springs, just to lower my ride, would I need a camber kit?
Acura/Honda Driver til the day I die!
A. Not necessarily, but they may the stock shocks may wear out prematurely.
B. Not, but for $120 it is the best handling improvement for the money.
C. Only if an alignment check shows that you need it. Very likely if you drop more than an inch.
94 DC4 RS LSV/Turbo
a dedicated 1.5" drop can only be achieved from one of the 2
Tein S Tech Springs
Nuespeed Sport Springs
I would recommend getting aftermarket struts (koni yellows) if you want to do the drop the correct way, the factory struts will not live to see 30k miles with a 1.5" drop
I would do the progress rear sway bar as it tightens the rear during some highway driving
and finally, a camber kit isn't all that necessary if your toe is corrected during an alignment
see this thread for more info - https://acurazine.com/forums/car-talk-5/motorcycle-vin-check-147290/
Tein S Tech Springs
Too Fast TOO FURIOUS
see this thread for more info - https://acurazine.com/forums/showthread.php?t=147290
Originally Posted by MESLER
flydog what did you do to your TL-S?
AZ Community Team
Received 7,771 Likes
H&R Sports:
1.4" F / 1.3" R
No Camber Kit; Stock Struts. Camber on right side is barely in spec; on the left barely out of spec.
DEFINETLY (120%) get the Rear Sway Bar. Progress 24mm FTW.
1.4" F / 1.3" R
Ok everyone ive been out of thecountry and finally able to check this post. So what's the best opinion. I don't want to ruin my suspension by just putting springs on my TL-S but but if I need to add shocks and struts then do I go any further? I am not a street racer but just want her to look a little lower without ruining performance.
Originally Posted by flydog
A-spec suspension. But that will not get you 1.5". I ended up close to 1" up front and 3/4" in the rear.
2007 TL TYPE S ASM
MrHeeltoe
20
02-23-2023 01:54 PM
MetalGearTypeS
08-29-2016 08:28 PM
MrHeeltoe
09-29-2015 10:43 PM
