I Read wheels post, but still need help
Parting out 02 Type S :(
I checked out the various posts as well as the looong wheels and tires post. i didnt find this combo, so i am going to have to ask for help.
here's some specs:
19x8.5,bolt pattern 5x112 with a 42 offset
First thing thats important is finding out if the rims will even fit. I have a HR Sport OE drop, so it shouldnt be too bad, i hope.
i saw the abp tls with the 20X8.5 but i am still unsure.
Anybody can tell me if these rims will fit and what is the widest tire size i can throw on them, f/r.
here's some specs:
Received 1,080 Likes
Wrong bolt pattern. You need 5x114.3. They won't fit on the stock wheel studs. Next.....
20x8.5 will not fit. 8.5 is too wide for our car. Even with a +55 offset they will rub on the suspension arms.
The widest for 18s or 19s is 18x8 +48 to +52 Anything less and it will rub on the fender, anything more and it will rub on the suspension arms.
he said he had spring stoppers, and it would prevent the wheels from rubbing unless he would hit a deep dip. my guess is that he got the springs to Stop at a certain point before rubbing begins. the only bad thing from that is the shock is probably taking alot of the hit, and so is the entire car.
i checked it out again, he can get the right size bolt pattern. but the closest he gets is 19X8.5 and 42 offset. so it looks like i am out of luck!
mada51589
05-03-2022 08:54 PM
asahrts
09-04-2015 05:55 PM
