i need a camber kit. HELP!
05' WDP A-SPEC
i dont know shit about a camber kit (never even heard of it until last week) and need some help. where do i get them? whats a good brand? do they void any kind of warranty?
i was told i need 3 but should i just get all 4 done?
any help would be greatly appreciated!!!
Im using SPC kits and i got them from MrHeelToe on this site...i know Excelerate sells em too..great units and they get the job done...i mean even if it voids the warranty they are still a must if ur dropped. Save ur tires so u wouldnt have to spend extra money because ur tires are wearing unevenly.
Travis
05' WDP A-SPEC
Originally Posted by Darkcyde024
no real need for the camber kit on the tl. just make sure you get a good alignment with the correct toe and you'll be fine!!
|AM.UA6|
are you sure about that? my camber is almost a whole degree off on the rear. they were able to get my toe perfect. so you think the toe is what made my tires wear so quick last time? my toe was off before by over a degree and a half.
I have a prelude with close to 2.5 negative camber on the rear, and the tires are wearing quite evenly.....so I wouldn't worry about it.
my alignment was screwed after my springs settled. -3.2 camber on one wheel. i ordered the eibach camber kit from www.drivewire.com for $140 shipped & my alignment is all in the green now. i only needed it for the rear. they are adjustable control arms. it came in an eibach box but the part says S P C. the ride feels sooo much better.
Moved to the LOU
A degree and a half is a lot for toe. That will account for a lot of your tire wear.
i actually talked to mr.heeltoe about this issue while he installed my shocks. when it comes to tire wear, he said it's not about the camber, but about the toe. and it's true, you should see the camber on my girls 350Z! and her tires are perfect. i would be interested to see if it helped the ride quality though!?!? for only $140, doesn't seem like a bad mod.
05' WDP A-SPEC
wierd thing is, before i got a realignment with my toe waayyyy off, it felt like it handeled better. with the alignment, my toe was corrected, but the caster and camber remained the same (caster was already in). now my steering seems not as tight like im worried when i hit bends hard and when i accelerate, i get a bit of the wobbles in the wheel. why is this happeneing?
|AM.UA6|
If you feel that the car is wobbling after an alignment, then there is something wrong with the alignment or the lugs are loose. Double check your lugs to make sure they are torqued properly because I remember a member here had his suspension done, and the shop did not tighten the lugs correctly or up to spec and end up losing a wheel while driving. So defintely check on that. Did you take it to a reputable shop who knows their stuff or who specializes in only suspension work??
05' WDP A-SPEC
everything is to spec. nothing changed in the alignment except the toe was set to 0. my totque settings are 80lbs on the lugs just as acura specifies.
MrHeeltoe
20
02-23-2023 01:54 PM
emailnatec
29
09-28-2018 04:27 PM
MrHeeltoe
09-29-2015 10:43 PM
MrHeeltoe
09-28-2015 05:43 PM
