Hubcentric rings+spacers?? what to do?
Im getting a new set of wheels.. +40 offset im trying to be at 35+, so im assuming 5mm spacers should take care of that.
With only 5mm.. i should be fine on stock studs correct? Also
what do i do about the hub centric part?? is there a certain spacer i need for my car or how do i go about a spacer AND making it centered?? let me know thanx!
talk to the tire store in person for an explanation of all these terms
centric rings are for matching diameter of hub on car- to center of new rim,
that way they get installed perfectly straight on the hub
94 DC4 RS LSV/Turbo
a 5mm h&r spacer hubcentric to 64.1 will still require a hub centric ring with the outer diameter of hte wheel hub and a 64.1 inner
or you could do what I do... go to wheeladapter.com and buy hubcentric inner and outer spacers which eliminate the hubrings and all chances of rubbing... pm me if you have any questions
mtl_ilx
09-03-2015 09:48 AM
stillhere153
02-19-2009 02:58 AM
fliplyricist1
10-15-2008 03:47 AM
doggydog
06-27-2008 07:40 PM
