HTspec damper...
HTspec damper...
I currently have tein ss on my tl. Ive had them for a little less than a year and my driver side, rear, shock is leaking. At this point I am very turned off with the super streets and am leaning toward getting the Function Form setup that heeltoe developed for the tl. My question is, is any one here running these yet? If so how are they.
Thanks for the replies. Im really considering getting these. Im just trying to figure out if the eibach setup is worth the extra 200 bucks or not.
The only differences between the two springs besides name-brand would be: the spring rates. I'm sure the Eibach springs would be much stiffer compared to the regular springs.
I had Koni yellow shocks with Ground-control coilover sleeves with the Eibach springs on my old car. (02 Accord V6 coupe) & I kinda miss the stiffness lol. But the regular springs rides nicely & I'm dropped pretty low
Im not sure how it blew out. The streets out here in NYC are pretty crappy but I find it weird that the rear one went out as opposed to the front which takes the worst punishment imo. Im leaning toward the htspecs cuz I know the extensive testing heeltoe has done. Like I said im kind of turned off with the teins.
i have had the type 1s for almost 5 months..now...i love these things very comfortable yet still handle well with minimal dive/roll in the twisties
still confused, the original F2's dont come assembled? Dont you just screw the pieces together and what not so that should be a problem, I still dont see the difference unless the spring rates are different etc..
reading is fundamental!!!!!!!!!!!!!!!...i just explained the damn diffrence
Chapter Leader (Central Florida)
The differences is this:
The F2 coilovers are designed for the TSX and accord, and require you to reuse the stock top hat from your stock suspension.
HT-Spec's are designed specifically for the TL, both in Spring Rate and in Valving, and come with a TL specific tophat.
06 ThugLuv
I have a 5at so of the three TL types I have the smallest sway bars. I feel at high speed turns my coils do more work the sway bars..I left my mud flaps on because it looks lower and I scrape those daily on high speed turns. (plus i have a low drop)....I’m planning to upgrade my FSB and RSB to a 27mm and 24mm. after research I feel the HT-2 w/ eibach and stiffer sway bars my tl will be perfect for me.
With stiffer sway bars I can lower the damping. Wich will solve the issue of my coils doing all the work and the extra rough feeling driving in the city.
I’m a fan of HT-spec 2 w/ eibach. I very happy with the service from healtoe also.
408acura (06-19-2011)
Thanks for the info everyone. I ordered some type 2s with the regular spring setup. They should be coming in next week. I will keep you posted with results.
06 ThugLuv
So i take it you have a 5at like me then? well i would have liked to done the sway bars first but the stiffer sway bars with stock 5at springs can cause problems..so ur gonna have to do the coils first.
So idk about you but I want the progres 24mm RSB..and the honda genuine 27.2mm FSB...but theres two options for that. The Type-s FSB is solid for $89. but the same diamiter for the 6MT wich is a hallow FSB is $149...Its clear to me that the 6MT FSB is lighter then the Type-s bar. on the Healtoe site they push the hallow one over the soild one..
But is there and advantage to having a soild bar? why would Acura put the heavier bar on the type-S?
Just installed them today. I still have to break them in but so far the ride is great. I like the fact that you dont have to mess with the spring perch. Also I really noticed a difference when adjusting the damper. I stiffened the front about two clicks from the factory setting and I really felt the difference. The only thing I do not like is that I couldnt put the factory strut tower brace back on because it hit the damper adjustment knobs. Did any one else run into this problem?
06 ThugLuv
how many clicks are you adjusted to? there 32-33 click totaly i think ..my fronts +20 and my rear is +25.
also im going to cut out two holes in the hat rack in the back so i can easily adjust the rear coils with out removing anything.
duuude i thought the same thing so i drove with out it for 2 days...and i was laying in my bed like "f&*# that" so i grabbed my parts and went out to my car with a flash light and tried it again...idk the first time i tried it i must have been doing somthing wrong...because now i have my HT-2's withtmy strut bar brace installed also...give it another go!
06 ThugLuv
I dont know man, when we tried to put the brace on it was really right on the knob. I didnt want to force it down and damage it. I guess ill try again tomorrow, if not ill make holes in it lol. As for the clicks, im not sure. In the front i did two to the right( stiff) from what ever setting it was at from the factory. In the rear I went two to the left and i think thats full soft. I like how its taking the bumps so far. The springs still need to settle tho.
Word up..Yeah man try again but drilling a hole will work, shouldn’t have to though...eventually I want this RV6 strut bar that doesn’t block the damping knob.
Man I must be too low because i had them on 15 at first and I felt I was bottoming out...
Do you have a 5at, 6mt, or t-s??
The reason I ask it because the sway bars are all different size..I have the 5at feel they hold me back and the coils want to go faster in turns...i love how I have just a little ass sag when I step on it and little front sag when i brake
06 ThugLuv
I have an automatic also. I actually upgraded the rear to the progress 24mm swaybar a while back . The front is still stock but I changed the bushings with energy bushings. Its tricky to find a good setting out here in NY cuz the streets are terrible. You can be on a smooth road and all of a sudden its full of bumps. anyways I didnt get to drive it much today but ill keep messing with it tomorrow. I cant really push it cuz it wont stop raining out here.
If you do, and you have the progress bar in the rear...do you have under steer? like where you turn the wheel a little bit and the car feels like it turns more then it should?
I just got on the XLR8 group buy for the RSB but i was thinking i should hold off on the install untill i get the 27mm FSB...do you thing ur going to upgrade ur FSB?
So you got the 5 speed auto? (idk if theres a 6 speed auto)
06 ThugLuv
The progress bar has a soft and a stiff setting. I have mine on hard and it feels great. I really feel it when taking turns at higher speeds then normal. I never tried it on soft but I feel that it compliments the front bar well. I wouldnt replace the front bar only because it is pretty thick. if you switch both I think you would be back where you started IMO.
But yeah if you get the 27mm fsb with your progresse bar itll be the same set up as a tl-s....it's just not as easy as the RSB..
Yea I would install the rear and play around with it before you decide to change the front bar. Anyways, ive been driving the car more and I gave the front 2 more clicks. It feels like stock now when taking bumps. The only bad thing is that It settled a bit to low. I will have to raise the car a bit because my tires rub a bit and I hit the bump stops from time to time. New York streets suck!
MrHeeltoe
1G TSX Photograph Gallery
10-17-2014 10:26 PM
MrHeeltoe
08-09-2012 05:58 PM
