How often should you rotate tires?
How often should you rotate the tires on a 2008 Acura TL Type-S? The Acura dealership said b/c it is fwd that I should have it done every 5k miles....this doesn't sound right to me as I have always been told to do it every 10k miles. Anyone know????
If you just move front to back, then technically, you would only have to do it once right? Once half the tread is gone in the front, move them to the back. Simple. I never rotate because I have a set of winter tires on rims. When I change them over, I just put the one with most tread in the front.
They can don a better job with the explanation:
http://www.tirerack.com/tires/tirete....jsp?techid=43
Registered but harmless
Received 1,102 Likes
Most street cars, whether FWD, RWD or AWD, will lose traction at the back first, then lose traction up front, so the tires with best traction go on the back to address that problem.
Oh, I rotate about every oil change (via MID) or every other oil change (if changing at less than MID-intervals).
With equal grip tires on front and back, most cars are setup to understeer, not oversteer. But when people put new tires up front, and old balding tires on back, they are artificially biasing their car to oversteer.
For example, look at the Pontiac Grand Prix GXP. From the factory, it comes with a staggered setup where the FRONTS are bigger than the back, with 255s up front and 225 in back. This is because the front heavy, FWD, GXP naturally wants to understeer, but with this staggered setup, balances the car out by biasing the tires to oversteer.
Yeah, but you guys are talking about hardcore traction. I just drive my car to work and back. I would never notice if the tires on one end of my car were half worn. If there are no internal issues with rotating once, and you don't autocross, then is it a safety issue?
You're in Alaska-- doesn't it rain there??
There's some white stuff that comes from the sky (not Colombia) that we don't get much of in LA, too-- that cold slushy stuff doesn't do you any favors with on-road traction.
Just think what could happen if you stomp in the brakes to avoid a moose or whatever emergency you have on the roadways there (polar bears? drunk Eskimo drivers?) and the car isn't straight...
On dry pavement or wet pavement without standing water, most cars will tend to understeer.... But like I said, my point was that when you start biasing traction towards the fronts, you are raising the chances to induce oversteer.
I also didn't say there was something wrong with oversteering. I'm just saying why you're supposed to put good tires on the back first. Most non-enthusiasts aren't accustomed to oversteer...
Over-correction then results in the rear end swinging out of control and losing traction at the rear first, if there is a loss of control.
Newer tires on the back = lower likelihood of loss of traction.
But if tires wear faster in the front, and you always want better traction in the rear, wouldn't that mean you never need to rotate? You'd just buy new tires when the fronts go need to be replaced, and put them in the rear.
Then let's say you wear down all 4 tires near the wear bars... and you decide you want to buy 2 tires now, and 2 tires later.... THIS is when you want to put them on back, cuz otherwise your back tires will be significantly inferior to the front, biasing your car to want to oversteer....
Same thing if you are lazy with rotations, and rotate at let say 15k miles when you wear down half the treads, so that when you rotate, your fronts are in like new condition, and your rears are half worn... Same problem...
Zonian22
11-14-2015 01:20 PM
Zonian22
09-02-2015 08:19 AM
