How many who are lowered needed front camber kit?
-------Tim-------
I am trying to get a feel for how many lowered TL's have had to use a front camber kit? And, which front camber kit? I have read a number of threads that discuss, getting away with just the rear, but would like to hear from everyone lowered 1.5"-2.0" or lower. If you can let us know how low you are dropped and what camber kit you have, and if your front camber is off. Thanks![Thumbs Up](https://acurazine.com/forums/images/smilies/thumbsup.gif)
Koni SP3/H&R Sprorts
Rear Camber Kit
(Front camber -1.3L and -.9R)
Rear Camber Kit
1st TL-S on air in
most people make the mistake that camber is what will make the tires go bald. Camber only effects the angle of wheel looking at the vertically. The only reason you would need more camber is for clearance to prevent rubbing. I am lowered on air bags and i run pretty low not sure what the drop is but i am running the skunk2 tsx upper control arms. My camber is not perfect to each side but that could be due to many numerous things. When i go to get my alignment i aim for the toe to be in check and camber to be close to each other.
-------Tim-------
-------Tim-------
"Like None Other"
i believe skunk 2 sells the upper arms camber kit for the tsx which is a direct fit for the TL. if the camber up front is still bugging you, go that route
-------Tim-------
so far im actually liking the re760s. i feel the wet traction performance is lacking a bit but i can deal with it. nice and quiet tire so far![Thumbs Up](https://acurazine.com/forums/images/smilies/thumbsup.gif)
i believe skunk 2 sells the upper arms camber kit for the tsx which is a direct fit for the TL. if the camber up front is still bugging you, go that route![Thumbs Up](https://acurazine.com/forums/images/smilies/thumbsup.gif)
![ugh](https://acurazine.com/forums/images/smilies/ugh.gif)
rest is all good though, tire pressure is good, maybe control arm is bad anyone have advice???
No camber kit installed on my car
handsom-hustla
11-13-2015 05:04 PM
09-04-2015 08:03 AM
nuldabz
09-03-2015 05:49 PM
