How high can you stack wheels/tires?
is there any problem with stacking 8 wheels/tires in a single column for the season? would this be too much pressure or could it deform the wheels or tires or something?
does it matter whether they are steel or alloy wheels? anyone have any idea? |
I doubt stacking them would be an issue. Just use some cardboard in between each wheel as a buffer so when you're stacking them you don't scratch the rim below it. I always stack my summer/winter set for the season with no issues. Granted that's only 4 rims at a time, but I don't think stacking 8 would be a problem either.
only issue is scratching the rim. if you're not worried about that it'll be fine. the rim on the bottom is holding 7 rims, which(with tires) come out to approx 340 lb. that's nothing because a wheel is impacted by over 1000 lbs of force everyday
sounds good. thanks.
half the year it's 8 winter tires on steelies, so i don't care about scratching. i'll put some cardboard between the wheels when i'm storing the summer/all season tires to avoid scratching, and put my wife's wheels on the bottom cause she isn't as picky about how the wheels look anyway ;) |
One thing to keep in mind is if they are on a cement floor you should have a buffer between the tire and the cement .. I usually just use a couple 2 x 4 on the flat.
Originally Posted by Acura604
(Post 14766440)
Originally Posted by Jesstzn
(Post 14766455)
http://www.canadiantire.ca/en/pdp/ho...-0468640p.html Heavy-duty tire hook mount easily on finished or unfinished walls Ideal for the seasonal exchange of tires Holds one full size tire and rim up to 75 lbs White scratch-resistant finish Fast and easy installation Dimensions: 3 ¾ x 8" (9.5 x 20.3 cm) Installed into studs of course. |
Nice! Well done.
don't tires sag if you store them vertically?
i wish i had more garage space. i'm in a new townhouse, and these days they literally build the garage to fit your car and that's about it. i could mount the wheels on the wall, but then i'd hit them with my door every time i get in/out of the car :( i'm glad i even have enough space to stack in one column in a little corner |
Originally Posted by anagramjones
(Post 14767013)
