HI! 2012 TXS wheels for '04 TL
could any one give me an idea about having TSX 2012 wheels on 04 TL. i dont know if it fit
2012 TXS wheels 5 Split Spoke 18x8 Inch, 5x115mm Bolt Pattern, One Piece Aluminum Alloy Factory, OEM Wheel, Rim (55mm Offset). http://www.wheelsandcaps.com/p-51732...8x8-71792.aspx current wheels on 04 TL SIZE: 17x8 LUG COUNT: 5 on 115mm offset 45 http://www.hubcaphaven.com/mm5/merch...egory_Code=304 thank you :tomato::tomato::tomato: |
TXS? never heard of that car
it will fit, however it will be 20mm less than stock. it will give a sunken in look, the wheel wont fill the wheel well nicely.
https://lh5.googleusercontent.com/-e...h542-no/M7.jpg |
If by chance, you are referring to the TSX as the "TXS" then given what Justin said, the wheel will sit 10mm further inside. In order to get to sit somewhere close to factory/flush a 25-30mm spacer and adapter is going to need to be run.
and your info is wrong 04 Acura TL runs a 5x114.3 not a 5x115 |
@paperboy42190 sorry i meant to say TSX, i wrote my post real late last night lol. thank you justnspace and JoshD_99EM1 for your helpful reply. i like the look of the new wheels but i find out i will hard time with it after your consultation
i did this to the wheels of my TL by the way. cheer! https://www.dropbox.com/s/2fn6tpofa1...2015.26.53.jpg |
