HELP on Varrstoen ES 2.2.2
I been thinking for a while on getting these wheels. But my concern is on how the fitment would be. I've contacted Varrstoen and they said i can run 19x9.5 +22 all around and all i would need is a 3 mm spacer in the front to clear the BBK. I would also need a fender roll which i don't mind but i DONT want camber. Anyone have this fitment on. I would like to see pictures from different angles.
My next thing would be just to go with 18X8.5 +15 which clears the BBK with no spacers and prob run 235/45 tire to have some meat on them
Are you lowered at all? All of those specs will fit fine on stock suspension but will be very aggressive if you're lowered. 19x9.5 +22 is 1.5" wider than stock wheels and 23mm more aggressive. 18x8.5 +15 is only .5" wider but 30mm more aggressive. Both setups will require rolled/pulled fenders, narrow tires, and camber.
You need to do more research before you make a purchase.
nuldabz
09-03-2015 05:49 PM
rudboy00
06-27-2013 11:09 AM
mrlal8
12-12-2011 05:36 PM
