Help with Tire Selection for Rims
Hi,
I just got a 2006 TL Automatic. Its the A-spec version, so it came with the body kit, and a drop of .5 or 1 inch drop (not sure).
I m thinkin of gettin some 18inch rims, the specs are as follows:
Bolt Pattern: 5x114.3
Off Set: +42mm
My questions are:
1) Will these rims fit on my TL without rubbing?
2) What is the best tire size because I have no idea what 235/45/17 refers to.
Any help would be appreciated.
Thnx
Off Set: +42mm
My questions are:
Thnx
Registered VTEC junkie
The rims specified are very close to A-Spec wheels. Just half an inch shorter in width. It should fit. You may want to go to a shop and do a test fit before buying them. The tire choices for 18" are 235/40/18 or 245/40/18.
BORICUA
Originally Posted by DTownEmcee
Thanks jchmax. How do i decide between the two tire recommendations or doesnt it really not matter? And will there be any problems sine I have the brembo brakes?
Thanks, so looks like I wont have a problem with the tires. But disppointed because the rims I had my heart set on are 18x7.5. Was wondering if you are 100% sure they wont fit or there might be a cahnce they fit.
I tried on some Volk wheels that are 17x7.5 42mm. I wanted the wheels but the wheels did not clear the Brembos. If I had an automatic (without brembos) , it would have fit. I do not feel that the wheels you're interested in will clear the brembos . The best thing to do is go to a tire/wheel shop and try on some wheels that are the same specs. You can also call Tire rack. They're really helpful with the "fit " issue. They try on wheels on different cars to verify fitment.
asahrts
09-04-2015 05:55 PM
