help me figure out the best dampening setting for my megans
04 5at. Right now I have the front and rear set at 17. I can describe this setting as a stiffer then oem but with less body roll around corners. Also, i dont feel like ride comfort/quality is sacrificed at this level.
I have the progress rsb set to soft and 10mm spacers all around if that even matters. I have my battery in the trunk along with 60lb sub/box and no spare tire. I dont have the front bumper support either.
Ive seen many people using 23 rear 22 front but they have a front bumper support and their battery is not in the trunk. Others just stay the same number all around.
Id like to upgrade to the type-s fsb but since I have to drop the sub frame and get another alignment, Im putting it off for a while.
I guess im trying to find a good balance between a firmer ride then stock with better handling. Should my rear be stiffer then the front since there is more weight then stock back there and the front has less weight?
People with megans, post your damper level and please explain what the ride feels like
JarrettLauderdale
2G CL Dynograph Gallery
09-21-2015 07:51 PM
MonkeyTrucker
09-21-2015 06:15 PM
braveheart
09-07-2015 08:12 AM
