HELP...Ingalls Rear Camber Kit
Ok, so i am in the process of installing my rear camber kits for my car. I've searched and searched and could not find an answer so i my question is, how do you get out the bolt with the oval shaped washer? it seems like there are two tabs preventing me from unbolting it and i cant hammer it out..what do i do? Here is a pic of the bolt i am talking about...Thanks ahead of time
![](http://i1015.photobucket.com/albums/af276/hengd1/Car/photo-2-1.jpg)
They should just come out, unless they're seized. all of mine came out, except one bar. I thought the same as you, turns out it was seized in there. Took it to a shop and they had to use a ball joint press and airhammer to get it out. Maybe try spraying and soaking it with PB blaster?? good luck.
Dino81 (07-10-2011)
09-04-2015 08:03 AM
nuldabz
09-03-2015 05:49 PM
