Help?
if u look @ the black and white picture with the stars around it, seems like its broken, the problem is the ride ins't smooth as much, when i hit bumps it feels as the car goes a little deeper and also when driving over 120KM+ it feels the alignment is off/so without fixing the problem cannot do a aligment
well its lose at the bottom where the rubber meets, and i think the front side (driveR) is broken to a point its sitting on the metal
I assume you mean that the steering wheel is shaking at 100-120 km/h (50-60mph)... Did the alignment shop tell you something is broke? By the pictures it looks as though your fork is fine.
Were the pictures taken while car was on the ground or raised?
Have you had your tires balanced?
Have you had new tires mounted? Tire rotation?
I am assuming stock suspension...
You need to take the wheels off to see if the connection from shock to fork is skewed/misaligned.... There should be a lip on the shock that should sit flush with the fork...
