Help with 3G sway bars
I have an 04 TL A/T base, and want to upgrade my front sway bar. I upgraded the back to a Progress bar, and the front feels kind of sloppy. What would be the stiffest front sway bar from other models that would fit my car? Id like to go with a type s bar, but dont know if the year and model difference would fit. Could someone give some input on this?
Former Sponsor
http://store.excelerateperformance.c.../i-539537.aspx
It's 28mm and adjustable.
The following 2 users liked this post by Excelerate:
justnspace (06-07-2012),
mattyd6911 (06-20-2012)
Ive been fighting a vibration and sloppy feeling in the front for a long time. I have 177k miles, but replaced all front control arms, oem springs, tokico struts, steering rack & pump, tires, end-links, bushings, etc. Still have a floating feeling and vibration up front. Could the lack of a better front sway bar up front cause this? Any other ideas would be very appreciated.
Last edited by Steven Bell; 06-17-2012 at 05:56 PM. Reason: Removed duplicate post.
I would say check out this site to look up a 07-08 Type-S bar..
http://www.acuraoemparts.com/delray/jsp/home.jsp
but if you are buying new then take a look at what Josh/XLR8 stated as well.. i havent gone wrong with his recommendations yet
one thing to point out though is if you are going to do a DIY then it is a little bit more complicated than a rear sway bar DIY
Former Sponsor
KzooTL (06-15-2012)
3G TL/2G MDX Owner
IHC did this mod, it took him ALL night without a lift. he thought it would be easy, but realized part of the way through that he had to drop the sub frame. he had to finish the job b/c he needed his car. there might be a DIY somewhere on here.
the RSB mod as you know was easy. 45-60 min tops (though some members had end links that fought back which quadrupled their install time).
is your suspension modded by chance?
AZ Community Team
Received 7,770 Likes
I was just gonna ask about this. Not sure that the OP changing the FSB is going to fix his issue. Seems more like shocks, bushings, etc. Or maybe something in the PS assembly (rack?).
3G TL/2G MDX Owner
i believe i saw the OP started threads on his suspension as well...so i'm not sure if he's trying to fix something, upgrade something, or both. he hasn't told us what he his goal was to change out the FSB. the implication is that he's trying to fix something by changing the FSB.
05' AT SSM
If you do it yourself take pictures and make a diy as it seems like a pain in the ass the first time around.
You don't have to support the engine from up top. I thought you did but it's not dropping out of there, trust me. I also did not remove all subframe bolts either, I just lowered it. The job would probably be 2x as quick if you did drop the subframe completely.... or had sunlight....or sleep.
Slpr04UA6 (06-19-2012)
AZ Community Team
A buddy and I tackled the FSB and it took us sometime to get it done. I upgraded to the Type S bar which needed to upgrade the end links to 10mm to 12mm. Which I need to drill out the lca hole to 12mm. Theres no need to drop the subframe as IHC stated. Just back out about 1/2in of the screw to give you some leverage. It was a PITA trying to get the new bar in and screw the clamps for the bushings back in. All in all, it took a few hours to do the swap with a jack and stands.
The following 2 users liked this post by lilsid112:
mattyd6911 (06-20-2012),
Sorry but I'm out of this one. There's just too much info and too many reviews that people have taken a lot of time to type up that you need to search for. There are detailed reviews of every swaybar setup. You have 2 FSB threads, 2 spring/shock threads, and 2 axle threads open at the moment.
It would be a lot easier for sure. I got hung up with trying to twist and maneuver the swaybar into position with the subframe lowered but not off. I could have knocked a ton of time off if I had just dropped the subframe completely or at least lowered it more..... and the fact that the instructions or the sticker were on the wrong side so following the instructions meant the bar would be upside down. I tried to picture it in my head and the instructions seemed wrong but I tried to get it in there for about an hour before I finally flipped it the right way.
But yeah, if you have half a day you can definitely do it. It's really not hard, just a little time consuming. I don't recommend doing it on your back. You could knock a TON of time off of what it took me with a lift and maybe a helper. I honestly think I could do it in under an hour right now. It's basically the same as the RSB except you're lowering the subframe and there's a little more fishing to get it in there. The part that sucks is the alignment that's required afterwards.
^^^Yeah, that's the killer for me too...just got an alignment done again.
I feel you Matt...I'm starting that transition from Noob that asks a bunch of questions, rather than just searching and getting in there and doing it yourself.
I don't know whether to laugh or cry from the multiple PM's asking "will this set up work". It makes me feel like "why the fk did I make a DIY, with pictures and also update my build thread, and answer the same question in other threads 10 different times". It's kinda insulting, almost.
justnspace (06-20-2012)
justnspace (06-20-2012),
-------Tim-------
Maybe rereading it will help? Everything was posted above that you would have to replace, and what to drill! If you try searching for sway bars for Acura TL, you will find everything you need to know.
You might have been better of starting 1 thread like another member here, either in prob/fixes subforum or here,with all your questions/upgrades and maybe requesting a link to some more reading material. ?
lilsid112 (06-20-2012)
justnspace (06-21-2012),
mattyd6911 (06-22-2012)
