Help with 20"
Help with 20"
I plan on buying sevas s22, but the guy says I should go with a 225/35/20 in the front and 255/30/20 in the rear? does that mean sense? the rims are 20x8 and 20x10, what tires should I be using?
BORICUA
did you have to roll your rear fender or make any adjustment, how many inches is ur car lower?
quick question to micheal...
the S-22's, you need a spacer to clear brembos right?? 5mm or 7mm ?? im pretty sure rodneyc77 said the s55's needed a spacer to clear too
