H&R Front sway bar with konis yellows and progress rear sway bar
I know yet another thread started by the guy who wants as much performance parts he can get his hands on on his car, only this time I have a question regarding how an H&R front sway bar grouped along with konis yellows and a progress rear sway will affect handling. I'm assuming most here haven't had any experience using all these parts together on their cars but I'll take a jab with this question anyway to see who can help. The reason I'm asking this question is because the user named Justnspace suggested I go with a different setup with the H&R front sway bar rather than konis springs because it might make the handling of the car worse so I wanted to find out from any of you guys if you have any experience with a setup of konis yellows and H&R front sway bar and how this affected the handling of the car after this setup was done?
I guess you are still new to the mod play ground, every body has different taste in mods kinda similar to food taste do you like your pizza thin crust or regular, extra cheese? extra sauce? You won't know the outcome unless you test drove someone car with similar set up.
Crab boy can tell you all day but in the end its his car that he might like it but may be for someone like me its too harsh..... BTW you post in the wrong forum section.
H&R front sway bar paired with a progress rear sway bar amd koni springs
almost the exact same setup I had...
I had aspec springs with koni yellow shocks and the Progress RSB. I didn't want to install the H&R front sway bar, because it involves dropping the subframe. I dont have the time to do that.
Did I say Koni springs? I meant Koni shocks lol and by the way I have H&R springs coupled with the konis.
Depending on the which Koni struts you have, you'll have a perfect set up that way. Not too low. Not too high. Not to rough and not too soft. It'll handle great. Not like race track great but for a DD, it'll be perfect.
killa combination
hANDYcaptd
09-01-2009 06:38 PM
XxxFrostyxxX
05-18-2009 12:24 AM
gsrevo6
26
01-22-2007 04:03 PM
Savio
22
09-13-2005 02:45 AM
