H&R Coilover pics, review
Wiggy Wiggy Wiggy
Finally finished the drop today. I waited a while for the springs to settle, and had the time to get an alignment done. The car rides great, very happy with that, was one of my main concerns. I did have one slight issue. The front spring ends were not smoothed out and had a slight edge that ate up the nylon washer and dug into the metal adjustment nut. H&R sent out replacements and I added a hardened metal wave washer. I found the perfect size from McMaster-Carr. Worked perfect and really made the adjusting easy. I had the alignment done by a master Lexus tech that has his own independent specialty repair/performance shop. He was diggin the ack, even complimented on how nice the car rode, considering its lowered.
![](http://i174.photobucket.com/albums/w81/power-flow/DSCN1913.jpg)
![](http://i174.photobucket.com/albums/w81/power-flow/DSCN1925.jpg)
![](http://i174.photobucket.com/albums/w81/power-flow/Misc-42808240.jpg)
![](http://i174.photobucket.com/albums/w81/power-flow/Misc-42808237.jpg)
![](http://i174.photobucket.com/albums/w81/power-flow/Misc-42808251.jpg)
![](http://i174.photobucket.com/albums/w81/power-flow/DSCN2007.jpg)
![](http://i174.photobucket.com/albums/w81/power-flow/DSCN2016.jpg)
AZ Community Team
Received 7,771 Likes
Nice.
I love H&R's stuff. I'd love to get those.
BTW, excuse my noob-ness, but what are these:
![](http://i78.photobucket.com/albums/j87/bearcat94/DSCN2007.jpg)
Camber Adjustment? If so, which manufacturer?
Wiggy Wiggy Wiggy
Yep, rear camber kit. Made by Ingalls Engineering. The shop owner also said they were a easy to use when when doing the alignment. I read about the rear inner tire wear problems, even with just the A-spec, so I def wanted to install a kit for the rear.
Registered VTEC junkie
Seems like a great set up. How much does this kit cost? Does it ride fairly smooth like stock? Thanx for the pics. This gives me a better look at the Ingalls kit also! I 'm considering those, I have A-Spec suspension. Yes, I've heard about not needing an alignment kit but you can definitely see the negative camber of the rear wheels compared to the front wheels..
Wiggy Wiggy Wiggy
It's around 1K. It's on the more expensive side for non damper adjustable. I would have used a mid range setting and left it anyway, H&R tunes the shock accordingly. For about a 2" drop it rides great, def still comfy for a DD IMO. Obviously any coilover kit is going to have stiffer springs, slightly more bouncy and more stiff ride, ect. I just like the look of them too, plenty of spring length. When I dropped it the rears did have a lot of neg camber just at eye sight.
Wiggy Wiggy Wiggy
I'm moving on to paint matching the bumpers, and A-spec kit next.
The ride height is set at about 25" in the front, 24 7/8" in the rear. From the highest point on the fender wheel well edge to the ground.
Nice drop and nice color AMFTW! +1 for staying with 17's. Would you recomend those camper kits to me i will only have eibach pro kit? also what you mean by paint matching your bumpers? they look good to me bro.
Wiggy Wiggy Wiggy
I don't know how much that kit drops the height. It's sure not going to hurt. The bumpers are off color, which is no biggie, looks better/worse at different angles. Its never going to perfect like solid black, but I can get the match closer, more acceptable to me.
MrHeeltoe
20
02-23-2023 01:54 PM
ITSJESTER
17
12-06-2018 02:29 AM
MrHeeltoe
09-29-2015 10:43 PM
MrHeeltoe
09-28-2015 05:43 PM
