Got my air ride finally, air suspension guys--help wanted
Old 02-02-2014, 03:25 PM
Redwood Original
RU_JELLY's Avatar
well I finally gave up and gave in to my number one thing I wanted for my TL. I ended up getting the airrex full bolt on setup and I went with the airlift autopilot v2 for my management with a single 400c viair compressor and a 4 gallon polished tank 1/4" lines. single water trap kit and smc check valve. I guess im just wondering if any of you 3G guys could help me out with any advice or tips from doing your own? I know this is a pretty straight forward install but im worried about where to run the lines and all that. Any help would be appreciated.
Old 02-02-2014, 04:27 PM
2004 TL SSM w/NAVI
Pghpizzaman's Avatar
congrats!! i'm jelly for sure. cant wait to see your setup sure its gonna be sick.
no help to you though im just an air ride dreamer lol
Old 02-02-2014, 05:06 PM
Redwood Original
RU_JELLY's Avatar
Haha ok man thanks
Old 02-03-2014, 01:30 PM
2014 Jeep SRT
ebelp's Avatar
Received 1,615 Likes on 1,030 Posts
Who did you buy your kit through? I was advised by the guys at Bag Riders to avoid the Autopilot V2 kit because of some front-end lift issues it has with Honda/Acuras. Even with Accuair management, you have to run AT LEAST 175psi (preferably 200psi) in the tank at all times, otherwise the front bags have a hell of a time raising the car. Unfortunately, the 400c compressor you bought is only rated at 150psi max @ 33% duty cycle. I highly recommend the Air Zenith OB2 compressors. They run at 100% duty cycle at 200psi. It's an amazing compressor that's worth the extra money. I'm also curious why you bought an SMC check valve...the 400c comes with one already.
Anyway, I ran my front lines behind my side skirts, but you can also run them through the interior of the car. Running them behind the skirts was a lot easier and even though it's been damn cold in NY all winter, and I haven't had any weather related issues.
Old 02-03-2014, 10:25 PM
Redwood Original
RU_JELLY's Avatar
I actually bought the stuff all from bag riders and was never told anything like that. hopefully it wont be an issue nothing I can do now. I could always add a bigger compressor/multiple later on I guess. As far as the smc check valve I read that the standard viair check valves are crap and the smc are much better so I paid the extra 25 for that, going by word of mouth since I don't know a ton about any of this. And ya I thought about running my lines up against the sideskirts too just didn't know if it was a good idea with them being plastic and if I happen to bottom out really bad it could easily fuck the lines up.
Old 02-04-2014, 06:28 AM
1islandparadise's Avatar
I havent ran air (yet) on my TL but ran air on my M45. I would have said to go with a different management system as the V2 autopilot doesn't accept certain accessories unlike the VU4 or even analog brass fitting setup. Honestly, I learned through trial and error, but it took purchasing a system first before I really started learning.
For my M45 I ran the air line under the car far away from the exhaust as possible. I doubled up plastic wiring loom and wrapped it with electrical tape in areas where my air lines were closer to the exhaust. Also, I would wrap the air line in electrical tape at each mounting point so as not to wear through the plastic hose. Also, purchase some liquid thread sealer for all your fittings. I believe bagriders sells it. Other than that, take your time with install and get a bottle with some soapy solution to spray on all the fittings after everything is connected to see if you have any leaks.
Old 02-04-2014, 09:35 AM
2014 Jeep SRT
ebelp's Avatar
That really surprises me because they were adamant about me not getting this kit at the time. Talk to Taylor or Rali at Bag Riders. They're the ones that told me not to get that kit. It shouldn't be too late. If they sold you something that won't work on your car, they should rectify the situation. You don't want to spend days installing this kit to find out that it won't work...then you'd be screwed.
Regardless, the max tank pressure you can safely run is 150 psi with the 400c. I've heard of people pushing Viair compressors to 175 psi, but I would imagine this would cause premature wear and kill it eventually. FWIW, I can tell you that the front of my TL will absolutely not rise unless there's at least 175-200 psi in the tank.
Old 02-04-2014, 09:47 AM
Redwood Original
RU_JELLY's Avatar
Guess I'll give them a call today then
Old 02-04-2014, 09:53 AM
2014 Jeep SRT
ebelp's Avatar
Trade your 400c for an OB2 compressor while you're at it! :wink:
Old 02-04-2014, 10:49 AM
Redwood Original
RU_JELLY's Avatar
Well I just talked to mike at bag riders were switching to switchspeed management with a free digi gauge worth $225 and I'm returning the compressor and have to find somewhere with the AZ in stock they have them on back order for months.
Old 02-04-2014, 11:46 AM
2014 Jeep SRT
ebelp's Avatar
That's cool, glad they could help you. You probably saved some cash going with the Switchspeed management. It's a good kit too.
Check ebay for the OB2 compressors. There should be plenty for sale there. Good luck
Old 02-05-2014, 10:38 AM
WDP Type-S sitting on air
rptls08's Avatar
i ran the lines on the inside of my car. it took a little longer than installs ive done where we installed under the car but i think it was worth it to prevent the lines from being subject to the elements.
Old 02-05-2014, 01:18 PM
Redwood Original
RU_JELLY's Avatar
Ya I'm thinking of running them through the car. I have to run 0 gauge wire anyways so I'll have to take my seats out for that.
Old 02-05-2014, 01:45 PM
2014 Jeep SRT
ebelp's Avatar
As long as you're using DOT-spec lines, they'll be fine on the outside of the car. The side skirts actually protect them from rocks/dirt, so the only thing you have to worry about is frozen lines, but like I said...it's dropped to double-digit negative temperatures this winter and I haven't had any issues. You can add air line antifreeze to your tank to counteract this also. Remember, DOT air lines are primarily used on the exterior of tractor trailers, so you know they're made to withstand a lot of punishment.
Old 02-05-2014, 04:33 PM
Redwood Original
RU_JELLY's Avatar
I got the line from bag riders so I'd assume they are DOT
Old 02-06-2014, 08:44 AM
2014 Jeep SRT
ebelp's Avatar
Yeah, they will be. They should have "DOT" printed on them.
Old 02-06-2014, 11:04 AM
I was waiting for the digi gauge when I purchased my touchbox module. Very interested to see how this comes out. I know with the touchbox module you are suppose to be able to view each bags psi wireless. If you have an iphone/itouch you should look into the touchbox module also. I had mine FS in the BM.
Old 02-06-2014, 11:36 AM
2014 Jeep SRT
ebelp's Avatar
The wireless features are neat, but I rarely use my iLevel app unless I'm showing it to someone. Using the e-level touchpad is a lot faster.
While you're driving, it'd a lot faster to just look at the DigiGauge itself....instead of unlocking your phone, put in your passcode, find the app, start the app, wait for the app to connect to the Touchbox's wifi signal, then wait for the info to load...
1islandparadise (02-11-2014)
2014 Jeep SRT
ebelp's Avatar
Old 02-12-2014, 10:29 AM
3rd Gear
bigwormm's Avatar
ebelp what setup u running im looking 2 bagged as well ......
Old 02-12-2014, 06:08 PM
darian1789's Avatar
How do you feel about the 444c. And would dual compressors be just as good to help raise the car?
Old 02-13-2014, 08:49 AM
2014 Jeep SRT
ebelp's Avatar
Accuair E-Level with Air Force struts.
I don't like the Viair compressors. The Air Zenith OB2's blow them out of the water. I run a single OB2 and it's plenty to lift the car.
Old 02-13-2014, 08:52 PM
darian1789's Avatar
I hear that alot about the AZ's. But my final question is if I was running 2, which still cost less than 1 AZ, would it be able to handle the lifting. Im just unfamiliar with air suspension and if running two at the same time was possible in order to avoid that issue against running 1 weak Viair.
Old 02-13-2014, 10:33 PM
Steven Bell's Avatar
Received 6,470 Likes on 5,162 Posts
Would love to see pics.
Old 02-14-2014, 11:42 AM
Boogerlovers's Avatar
im running accuair e-level with dual viair compressors. I can confirm that john is right when he says that you must run more than 150 psi to raise the car efficiently and to make sure your car doesnt feel like a fucking boat when you are driving on a high preset. i havnt had any problems with either my compressors or my management. im still curious as to why people dont run accuair more often. i understand that its more expensive but i really do think its all worth the money. I had all the lines run through the interior and through the wheel well into the bags themselves. although im thinking of going hardlines in the trunk for a cleaner look.
Old 02-14-2014, 12:03 PM
darian1789's Avatar
Setup is looking nice. So would you say that running dual compressors help lift the car. And which ones did you get, 400 or 440?
Boogerlovers (02-14-2014)
Old 02-14-2014, 12:11 PM
i have the dual 400 compressors they help the recovery time and helps me run the tank at higher pressure. i was running the tank at 150, which is the setting its sent to you with and it was horrible. the bags definitely had a hard time supporting the front of the car. i bumped the pressure up to 175 and its great, im gonna run it at this setting for another week, and then ill try 200psi.
Old 02-14-2014, 12:53 PM
maharajamd's Avatar
Received 1,544 Likes on 1,197 Posts
Old 02-14-2014, 01:36 PM
takin care of Business in
swoosh's Avatar
Received 4,732 Likes on 4,064 Posts
subd
Old 02-14-2014, 01:39 PM
2014 Jeep SRT
ebelp's Avatar
You'll shoot your eye out, kid! Seriously though...do some research before running 200psi with Viair. I would imagine the chances of prematurely burning out the compressor motor is very likely.
Originally Posted by maharajamd
Need something?
Old 02-14-2014, 02:03 PM
2014 Jeep SRT
ebelp's Avatar
Regardless of how many Viair's you run, you aren't supposed to run them beyond 150psi. Obviously people do anyway, but IMO it's worth the extra money to get a compressor that's built to handle 200psi with no issues. Plus it works at 100% duty cycle. Viair has one model that runs at 100%, but the CFM rating is weak.
darian1789 (02-14-2014)
Old 02-14-2014, 03:16 PM
im looking into the air zenith OB2's, and i might order two of them and sell my viairs. they look better and flow twice as much as the viair480c's. and ill get two just to make my own brackets so that i can keep my exo mounts . thanks for the heads up john.
Old 02-14-2014, 08:55 PM
2014 Jeep SRT
ebelp's Avatar
Sounds great. Keep us updated on your progress!
Old 02-14-2014, 11:10 PM
I like it!
Old 02-19-2014, 06:42 PM
Elricooo's Avatar
Where did you mount your sensors I'm upgrading to e-level pretty Soon
Old 02-19-2014, 06:52 PM
Redwood Original
RU_JELLY's Avatar
Damn this threads been busy. So I am going with dual viair 444c they're sending them out tomorrow hopefully. The AZ is on back order everywhere. Messages 10 sellers that have one posted on eBay and they don't have them either. (Why are they posted then right ?) so I'm going to try them out and worst case sell them and get a AZ in March. Hopefully gonna start the install in the next week.
Old 02-19-2014, 07:42 PM
Elricooo's Avatar
I have the dual 444c compressors runs pretty good .. Fill up time is like 2min tops from 150psi to 200psi
Old 02-21-2014, 02:06 AM
speedy4ever's Avatar
Sorry to post on ur thread RU_JELLY, but im also about to pull the trigger on air ride and it seems that all the air pros are on here. Im about to order the accuair management with elevel and dual 440 viair compressors with 3/8 lines and airrex suspension.
I was originally thinking ksport but the vender told me that the airrex suspension from experience is better and last longer than the ksport. Does anyone have inputs on this?
Also can u guys check these prices? maybe I can get a better deal else where? They seem the lowest I could find. Thanks.
Accuair elevel management, dual 440c viair, 3/8 line, 5 gal tank $1995
Airrex air suspension $2250
Exo Mount $235
plus shipping, no tax
Old 02-21-2014, 07:28 AM
Redwood Original
RU_JELLY's Avatar
Yup prices seem right. Airrex is definitely the best. Ksport d2 and airtekk are all made by the same company from what Bruce says (acktl05) he talked me out of the e level. Does anybody know if you can use I level on switchspeed management without running e level ? Having trouble getting a clear yes or no
Old 02-21-2014, 10:18 AM
2014 Jeep SRT
ebelp's Avatar
The sensors attach to the fender wells, and then the sensor arms attach to the swaybar endlinks.
I asked Accuair about using the iLevel unit with the Switchspeed management. Some of the functions of the iLevel app will work, but you can't use any of the height preset buttons without having the e-Level height sensors. The iLevel unit is designed to be used with e-Level management, not Switchspeed.
Quick Reply: Got my air ride finally, air suspension guys--help wanted
