Getting rims, important question on tire size
'Big Daddy Diggler'
Will 235/45/18 fit or will 245/35/18 fit. Which one will be better and will not rub, especially if im thinking of doing a comptech drop in the spring. Let me know the best offset and tires i should get with no rubbing on stock, and a comptech drop.
those are pretty wide tires which will dictate what one rim width is the best fit (though there is a range). so going with this, the rim is pretty wide such that it might not be possible not to rub. maybe you should stick with either 7.5 or 8 inch wide rims, 225 or 235 tires, and something in the 45~50-ish offset range.
'Big Daddy Diggler'
Ok thanks. so how does a 18 x 7.5 235/45/18 sound. Any rubbing, can i do a comptech drop later on. Or must i get different tires or roll the fenders
nuldabz
09-03-2015 05:49 PM
Mugen TSX
Eastern Canada
09-01-2015 11:05 PM
