front sway bar???
front sway bar???
im just curious, did anybody change out their front sway bar...I found H&R front sway.... http://hrsprings.com/scripts/appguide.php?Mode=Application+Guide&SubMode=Find2& Year=2007&ModelID=8&q=2007%20|%20Acura%20|%20TL%20 Type-S
The FSB on the TL and S-type are thick enough as is, I can't really see a point in getting an aftermarket one. I believe the Type-S is solid vs. the base model, which is hallow. There might be a minor improvement for the base folks to upgrade to the Type-S, but I doubt its worth the time and labor. You probably have to drop the subframe a litte...not an easy task.
marcelft
07-10-2018 06:17 PM
k6biv
09-10-2015 06:37 PM
