Front lower balljoint issue
I’m doing a Lowery ball joint on driver front of my 05 tl and I’ve gone through three ball joints now! For some reason with the new balljoint in the castle but won’t go all the way up and tighten, so there is a lot of play, does anyone have a suggestion to fix this issue? Also the last balljoint I bought was from Honda dealer?
Pics? What ball joints/part# did you buy? From where?
there is a metal sleeve that presses into the lower control arm, where the ball joint attaches.
Is it present?
Or did you throw it away with the original ball joint you replaced?
Is it present?
Do you remember the old joint being a lot "fatter" than the new one?
Is the hole in the LCA a lot bigger than the ball joint stud?
If so....you need a sleeve since you tossed the old one.
I'm pretty sure acura sells the sleeve seperately
Have you tried just comparing the side you're working on to the other side?
no worries.
since you're new at this...
-Only use a genuine acura/honda joint.
-Only use the original Acura/Honda nut
-Follow the torque specs and procedures in the Acura shop manual.
they wouldnt sell the sleeve seperately, in fact they had no idea what I was talking about but I bought a whole control arm for $110 so that should fix the issue
They?
I mean...we kinda already know that whomever is working on the car doesn't know about the sleeve. Or you wouldn't be in this predicament.
Did you check to see if the Accord and TL use the same ball joint part number?
Hopefully your new control arm comes with it.
acuratl_2nr
1G CL Problems & Fixes
12-25-2007 01:57 PM
CleanCL
20
05-19-2007 05:27 PM
DjTrancesponder
03-15-2006 08:18 PM
