Front camber kit?
Old 05-06-2013 | 01:35 PM
shmakoo's Avatar
Front camber kit?
Noob question, but I tried searching and I could not find much. What is the difference from the Ingalls front camber kit and the Skunk2 one? I have read that on the Ingalls, you have to cut a hole because of the bolt hitting the top.
Old 05-06-2013 | 02:14 PM
TL Seth's Avatar
I believe you have to make modifications (cuts) to the skunk 2 as well. There was a DIY thread a week back
Old 05-06-2013 | 02:58 PM
SharksBreath's Avatar
BANNED
you don't HAVE to cut holes in your shock tower if you're using adjustable ball joints...but, if you are low enough you will get tired of hearing the UCA SMASH BANG CRACK against the tower so eventually you might just cut the hole anyway.
same with the skunk kit, sort of. you can modify the arms to dial in more negative camber IF you want to, you don't have to. skunk themselves can do this for you at the factory for an additional charge OR you can try it yourself.
again, both of these scenarios aren't necessary but optional.
The following 2 users liked this post by SharksBreath:
shmakoo (05-06-2013), Wacker (05-06-2013)
Old 05-06-2013 | 04:02 PM
TheDingo's Avatar
Resident Dingo
I'm telling you from experience. Spend more and buy the Skunk2 UCA instead of the Ingalls adjustable bushings. They're a pain in the ass to adjust and my car wasn't even that low. Plus they will move and spin inside of the UCA which makes them even more difficult to adjust correctly.
Old 05-07-2013 | 11:26 AM
Excelerate's Avatar
Former Sponsor
INGALLS just sells adjustable ball joints, SK2 sells an entire upper control arm with adjustable ball joints. So the SK2 kit is a better setup since it will offer more adjustment.
shmakoo (05-08-2013)
james357
02-13-2016 03:37 PM
o8 ENVII 8o
11-30-2015 05:23 PM
08 NBP TL
09-08-2015 09:49 PM
09-04-2015 09:03 AM
nuldabz
09-03-2015 06:49 PM
