Fresh Waffles Anyone?
Ok so I don't really post much, but this thread is really for anyone with the stock Type-S rims who has curb rash. I purchased my Type-S in October, and now that its getting warmer, I decided that I was going to try to tackle the awful curb rash that has been bugging me since then.
First things first, the before pics:
First thing I did was to buy a 12oz can of the AM spray paint, and clear coat from www.paintscratch.com
Then I hit the rash with 180 grit sandpaper, after getting all the paint off around the rash, I mixed up a little bit of bondo (though I'm sure any kind of body filler would work just as well) and caked it onto the gouges.
After letting the bondo dry, I sanded it all smooth with 200 grit sandpaper, cleaned with some No Sand pre paint cleaner, and taped off around the rim.
Finally I sprayed on 3 coats of the paint, first very light, the next, a bit heavier, 15 mins between coats. The real trick here is that I didn't paint the whole rim, only the outside edge. The touchup paint was definitely darker, so I had to do my best to blend it into the stock color. I finished up with 3 coats of clear (spraying 15 mins apart just like the paint).
When the clear coat was dry I buffed it with a little bit of rubbing compound to make it shiny and smooth.
Here were my results:
Personally I think they came out quite nicely, and for around $30 for everything, you can't ask for much more.
It only took me around 4 hours total for one rim, and thats including drying time, etc. Hopefully this weekend I'll be able to get another 1 done
Turbocoop (05-24-2012)
I like turtles
Good work. I have two rims with pretty decent curb rash but it doesn't bother me enough to go fix it lol. The color of these rims hide it pretty well
Received 3,824 Likes
Nice, they look great!
You can also get the two part catalyst clear coat in a spray can. (A bit mroe expensive $20 bucks a can) This dries harder than an enamel air drying clear coat and you can buff it to a car shine gloss. Here is a link to a company: http://www.spraymax.de/index.php?id=361&L=1
Wheels turned out great tho.
excellent work! might have to give this a try.
3 of the 4 of mine have a little rash. nothing serious, but still. I was thinking of doing a time attack stripe to try and hide, but it really doesnt look right on these wheels.
Looks like it came out good. I bought my A-Spec with curb rash on 3 of the wheels. I was gonna get em repaired and powdercoated but I dont have the time or money. I might give this a shot, just as a temporary fix at least. Im wondering how thats gonna hold up over time. You should put some more pics up in a month or 2. Thanks for the DIY
Thanks to all for the generous comments
I was in pretty much the same situation as most, don't really have the money to shell out and have them repaired or replaced, plus I couldn't even stomach if I ended up curbing them after paying to have them done professionally.
I will definitely post up some pics after a few months to show how they are holding up. I am hoping to eventually pick up a cheap pair of 04-06 or even 07-08 stockies and slapping on some snows for the winter so that would probably even heighten the chances of this repair lasting longer.
RLTW!!
Excellent job!
Received 6,470 Likes
Nice work LSD. Get some tire black and you'll be set!
Biggie_B
02-26-2017 11:14 AM
08_UA7_Gr33k
02-11-2016 02:17 PM
08_UA7_Gr33k
09-27-2015 01:56 PM
AcuraKidd
09-25-2015 11:18 PM
