Fall is in, winter is coming. Rubber time..
I'm needing new rubbers now, my stock tires are starting to not listen to me.
Understeers very easily in rain, wheelspins even if I go light on throttle etc.
What are some tires you guys might suggest for the TL-S that fits this time of the year or just can deal with wet and dry?
I'm still running on stock Type-S wheel/rims.
wow, thats really odd, have you checked the depth of the treads on the tires? I would highly suggest you contact acura if the tires are wearing to quickly as you may have a bad batch of tires or the alignment might be off.
Probably the tires, but I don't think I can do anything to Acura about it. I've already had the car for 5 months now.
rebmeM deretsigeR
You sure its not the roads? Fresh rain on pavement that hasn't seen rain in a while tends to be slippery, moreso than usual. All that oil, grease, dust, etc.
and I feel alot more of the understeer when I take a corner more agressively. Kinda makes me unconfident with the corners I drive on everyday.
Umm...
Where about have you been driving to experience this?
I never experienced the wheelspins or understeer you're describing. The TL-S shouldn't have a big difference in power at lower rpm's compared to the TL, right?
There was once I had a scary understeer when I was exiting out the freeway on a big 360 degree turn ramp. But I was simply driving too fast at that time, so I don't think it has anything to do with the tires or the car itself.
Originally Posted by ck25
Umm...
Then on SW Marine dr. , car felt unstable, felt like hydroplane. Wheel spins off stop lights in the rain, which happens almost any where.
Also, the car had a bit of a wheel spin when I downshifted from 3rd to 2nd and accelerated.
Are you sure you mean "understeer"? That is the tendency of the front end to "plow" and scrub off speed. Maybe you mean "oversteer", where the rear has a tendency to slide, especially into corners. This is the usual tendency for worn tires, and is prevelant in the Michelin OE tires when they get over 10-20,000 miles on them.
Back to point, best all seasons seem to be Goodyear F1 A/S, and my favorite, the Michelin Pilot Sport A/S's. Potenza 960 seems to rate highly too.
Check out
www.tirerack.com for good comparisons.
Check out
Originally Posted by elkayem
Understeered last night at the "S-turn" where you turn onto Russ Baker and onto Arthur Liang Bridge...
I don't know about up in BC (tho I'll be up there next week), but down here we just had the seasons first cold snap. (First snows in the passes, and night temps down in the 40s, etc.
I know cold temps + rain, means you have to have a good tire....
In my G35 for example, when it was still wearing the stock Michelin Pilot Sports Summer tires, I had crazy problems with tire-spin and the back end kicking out on moderate curves, when it was misty and 45 degrees.
I talked to a guy at tire-rack, who explained that "summer" in summer tires means average daily temps > 60 degrees and average nightly temps > 50 degrees.
Even our TL, I had a similar problem even with the stock All/Season tires it came with, tho not as pronounced... (Wheelspin on light acceleration in the cold rain)
However, after installing Michelin Pilot Sport A/S on the G35 and Bridgestone Potenza RE960AS on the TL, my problems went away. I'd highly recommend these tires if your looking for All-Season tires. Tho I'd get the RE960AS over the Pilot Sport A/S, because my Pilot Sport A/S only lasted 20,000 miles, so now all my cars have RE960AS at the moment.
At any rate, if you get a set of new tires, tell us how it goes!
Originally Posted by avs007
What was the ambient temperature at the time?
I just put Kumho Ecsta ASX on mine and they are fine in the wet and wet cold.
I'll be going to the dedicated winters pretty soon .. eg. next week.
And its colder here than at the coast..
Check out
Check out
Any sites I can take a look at these at? or get these?
Head a da Family
I think I might just look into that...
Goodyear Eagle F1 All Season user reviews on www.discounttire.com:
http://www.discounttiredirect.com/di...TiresBySize.do
Goodyear Eagle F1 All Season user reviews on Tirerack:
http://www.tirerack.com/survey/Surve...e1=yes&place=0
SidhuSaaB
05-30-2020 12:40 AM
detailersdomain
Wash & Wax
10-09-2015 10:13 PM
