Excelerate Performance: TEIN Street Flex Now Available!!!!
Old Dec 11, 2013 | 10:43 AM
Excelerate's Avatar
Former Sponsor
Excelerate Performance is excited to announce that the TEIN Street Flex is now available for the 3G TL (04-08). The Street Flex damper is the evolution of the popular Type Flex coilover. Developed to provide the ultimate balance of comfort and performance for both street driving and circuit use, along with wide-range damping force adjustment using our new Advance Needle technology and new damper valving specs, giving the driver a much more noticeable feel in damping force change and controllability. The shortened shell case design provides optimum damper stroke at lower than standard vehicle ride height. Full-length adjustability offers separate spring preload and ride height adjustment. Updated internal components and external coatings increase durability and product life. Includes Pillowball Upper Mounts and is compatible with the EDFC and EDFC Active systems.
You can purchase them here: http://store.excelerateperformance.c...i-1875773.aspx
Additional Features
• Steel Construction
• Twin Tube Internal Construction
• Full-Length Adjustable via Threaded Body and Spring Seat/Seat Locks
• 16-Way Damping Adjustable (simultaneous compression and rebound)
• New Damper Valving Specifications for Improved Street Comfort
• Incorporated Advance Needle Design (nearly 200% improvement over predecessor)
• Pillowball Upper Mounts for increased steering feedback
• Camber Adjustable for Strut Type Front Suspensions
• Larger Piston Diameter (22mm O.D.) for Strut Type
• EDFC (Electronic Damping Force Controller)/EDFC Active Compatible
• Powdercoated Brackets and ZT Coated Shell case for Outstanding Rust Prevention
• One Year Warranty Against Manufacturer's Defects
Old Dec 11, 2013 | 11:42 AM
pohljm's Avatar
Pricing?
Old Dec 11, 2013 | 11:56 AM
cust0mx's Avatar
$1215 according to their website.
Old Dec 12, 2013 | 01:00 PM
cokorote's Avatar
I have not much knowledge with the coilover department but how "better" are those coils to the competitor like BC, ISC, KW or other?
Old Dec 12, 2013 | 04:58 PM
Excelerate's Avatar
Former Sponsor
Well what are you looking for in a coilover? Then we can determine which is better for you.
TEIN is a great company because of the quality, ride height adjustment, damping adjustment, durability, proper spring rates, valving, etc.
Old Dec 29, 2013 | 07:57 PM
Chad05TL's Avatar
So, comparing to Street Basis and Street Advance, the Flex version really shines at extremely lower levels... correct?
And what is the range of adjustability from factory ride height?
Old Jan 2, 2014 | 06:18 PM
Excelerate's Avatar
Former Sponsor
The TEIN Street Flex is very different from the SA/SB. It does have damping adjustment and a twin tube steel construction, but it includes pillowball upper mounts as well as a fully threaded shock body. This allows you to pre-load the spring and make your adjustments on the body of the strut for height.
http://www.tein.com/products/street_flex.html
Old Mar 6, 2014 | 06:11 AM
4drviper's Avatar
Correct me if I'm wrong,
Pillowball upper mount = It comes with top hats
Fully threaded shock body = I do not have to touch spring perch to adjust ride height
Those look delicious.
Old Mar 6, 2014 | 05:10 PM
Excelerate's Avatar
Former Sponsor
Correct and correct.
And we now have a number of these kits in stock at our shop!!
GWEEDOspeedo
Jan 15, 2016 10:39 PM
ExcelerateRep
Oct 14, 2015 08:20 AM
jmaxima03
Sep 27, 2015 10:22 AM
ExcelerateRep
Sponsored Sales & Group Buys
Sep 22, 2015 10:39 AM
