Enkei RPF1 18" SBC Help.
Old 11-05-2015, 11:40 PM
KBTypeS's Avatar
I am in the market for some new wheels. What I currently have is a 07 TLS.
I want the wheels to be flush looking and I don't have to have to used spacer or where the wheels poke out. I also don't want he tiers to be stretch as well.
what size would be good to do that?
18x9 offset offset
or
18x8.5 +30 off set
Old 11-06-2015, 06:11 AM
guitarplayer16's Avatar
Received 2,316 Likes on 1,690 Posts
whats the offset of the 18x9 wheel?
Old 11-06-2015, 08:08 AM
Andrew
VisualEchos's Avatar
You want 18 x 9.5 +40, but 18 x 9.5 +45 will work as well. Tire can be a 255/40 or a 265/35. I recommend the 265/35.
With a +40, if you're not dropped at all, you'll poke 5mm in front, but as soon as you drop it even a little it'll fit perfect.
Here Comes the Sun...
by Andrew Thompson, on Flickr
Meat.
Old 11-06-2015, 08:10 AM
Andrew
If you're looking for a perfect solution with no drop, then choose 18 x 9 +40 with the 255/40 tire.
Old 11-06-2015, 08:21 AM
Andrew
Here are pix of the 18 x 9.5 +40 with the 255/40 tire and no suspension mods whatsoever. The 255/40 is slightly taller, which makes the car appear to be dropped a bit, when it's actually not. It's also a smoother, softer ride than you'll get with the smaller sidewall tires.
Summer.
Miro 112.
As I said, this set-up will poke 5mm in the front, but NO ONE would notice. You'd really have to be looking for it. This is the very best size of wheel/tire combo for the car if you don't want to do any other mods (IMO). Look is fantastic, ride is fantastic, and the fit is damn near perfect. 18 x 9.5 +45 would have hit the nail right on the head, if you don't want to drop the car.
Old 11-06-2015, 09:45 AM
KBTypeS's Avatar
+38
Summer.
Miro 112.
im not sure if it will work consider what your showing is a base model. Brembo Caplier is a little different then the base model one. Plus it different type of wheels.
Old 11-06-2015, 10:23 AM
Andrew
Ah, forgot about that pesky BBK.
Old 11-11-2015, 02:22 PM
sockr1's Avatar
Received 1,160 Likes on 909 Posts
Originally Posted by KBTypeS
+38
usually anything bigger larger than a +35 will not clear the brembos and most +35 won't clear either (enkei raijin 18x8.5 +35 does however, others like avant garde and vmr with not clear with a +35)
the brembos make it super tough to find a good wheel that clears the brembos but is not too aggressive.
i just put in an order for tsw nurburgring wheels, which are 18x9 +32, i talked to a member that said this cleared his brembos.
point of the story is to do lots and lots of research on what other members have used for the wheel you're looking for. i spent about 3 months researching wheels and member setups to narrow it down to the one i just ordered. wheel and tire fitment is very tough with the brembos on our cars
Oh Sickest TL (11-11-2015)
Old 11-11-2015, 02:44 PM
Jeff
Oh Sickest TL's Avatar
is 18x9.5 +45 with 265/35 and slight drop hard to accomadate?
Old 11-12-2015, 08:12 AM
Andrew
For a Base, not at all. In fact, it's damn near perfect, requiring only a slight roll in the rear.
For a TL-S with Brembo's, I have no idea.
Oh Sickest TL (11-12-2015)
Old 11-12-2015, 10:46 AM
2014 Jeep SRT
ebelp's Avatar
Received 1,615 Likes on 1,030 Posts
I've heard from the Subaru guys that the 18x9.5+27 nt03's don't play well with factory Brembos. The spoke design of those wheels is very flat, so you have limited clearance. Every car is different, so that might not apply to the TL, but hopefully a 5mm spacer will make everything fit if there's no space. If a 5mm spacer still won't give you enough caliper clearance, your only options are to go with a larger spacer + extended studs, or get a different wheel.
rockstar143 (11-21-2015)
Old 11-20-2015, 12:45 PM
CL721's Avatar
the standard RPF1 in 18x9 only came with +35. i'd go with the 18x9
Old 11-21-2015, 08:24 AM
rockstar143's Avatar
Received 20,015 Likes on 14,518 Posts
Basically, concavity come into play...some pretty weak offsets will clear if the face is not concave...once you start bowing the spokes inward, then can limit clearance on the brakes. Same with a lipped wheel...3" lip but weak offset might still run into trouble.
Then again, I hear harbor freight is running sales on angle grinders
Small spacers can solve a lot of issues but clearing brembo AND running a 265 rubber probably won't jive.
ebelp (11-24-2015)
Old 11-21-2015, 08:25 AM
I think the NT's have 2 different styles though, one is more convex which I don't like the look of, but will probably have no problem with the brakes.
Old 11-23-2015, 08:34 PM
KBTypeS's Avatar
you guys think 18x9 +35 rpf1 would clear brembo
or
18x8.5 +30 rpf1 ??
Old 11-23-2015, 08:49 PM
sockr1's Avatar
Contact enkei directly. They are very responsive and knew what fit my car and what didn't when I emailed them
Old 11-23-2015, 09:24 PM
Confusing Name Guy
N1h1l1ty's Avatar
This. Probably one of the best companies to deal with in the wheel world. I think the 18x8.5 +30 is much more likely to clear as it has a convex face. On the other hand I think it looks rather fugly compared to the 18x9.5 +15 for example which is a fair bit more concave and DEFINITELY clears (confirmed by people on here). At the same token, 9.5 +15 is a very aggressive wheel spec - You should talk to shotta on here who runs RPF1s 9.5 +15 in the front and 10.5 +15 in the rear I believe.
Old 11-24-2015, 08:31 AM
KBTypeS's Avatar
Thanks man i will ask him about it
Old 11-24-2015, 08:37 AM
Enkei has some new wheel options coming out that are teh sex...
just sayin...
TS9
Old 11-24-2015, 09:01 AM
KBTypeS's Avatar
just sayin...
TS9
I'm actually got 3 wheels in mind
Advance rs
Volks Ce28n
Enkei rpf1 sbc
Old 11-24-2015, 10:31 AM
Well, option 3 will save you at least $1000...
and it's Advan, brother...
Assuming Advance isn't some new version of it!
Also, the Advan RS are hard to find! You'll have to go RSII if you go new!
Old 11-24-2015, 08:44 PM
KBTypeS's Avatar
Yeah I know it will save some money. I can always try to find a used set =)
for some reason I like the RS..I we always wait it out
Old 11-24-2015, 10:55 PM
LOL...I kinda like the RS too
Oh Sickest TL (11-25-2015)
Old 11-25-2015, 07:59 AM
KBTypeS's Avatar
Old 07-17-2016, 08:07 AM
KBTypeS's Avatar
anyone know of a contact where I can contact Enkei to see if 18x9 +35 rpf1 will fit brembo?
Old 07-17-2016, 09:02 AM
LIST/RAMEN/WING MAHSTA 짱
princelybug's Avatar
Enkei International
1111 Executive Dr #100
Coppell, TX 75019
(817) 490-5600
You can also message them directly via FB if you use that.
KBTypeS (07-17-2016)
Old 07-17-2016, 10:32 PM
KBTypeS's Avatar
Thanks man!
Old 07-18-2016, 05:32 PM
4DGSR's Avatar
They will fit. I went 18x8 +35
235 / 40 / 18
Lowered with Tein Street Flex Coilovers
Old 07-19-2016, 08:08 AM
llllBULLSEYE's Avatar
you should see if the 18x9/9.5 with flat face will fit. I personally find the 18x8/8.5 bubble versions don't look as good
eric.
03-08-2016 06:01 AM
Skier4lyfe303
02-18-2016 01:23 PM
n3o
01-04-2016 08:37 PM
mn763
1/2G MDX (2001-2013)
11-05-2015 06:58 PM
chris432
11-05-2015 02:05 PM
Quick Reply: Enkei RPF1 18" SBC Help.
