Enkei PK6
Enkei PK6
Does anyone know if the Enkei PK6 will clear the brembos on the 6mt TL? It's 18x8.5 35offset.
I asked discounttiredirect and they told me it will fit the 6mt TLs. I just want to be sure.
ummm i dunno about 35mm offset, most people say 45mm is what is needed to clear and i know the RPM2's clear and that is 42mm offset. it will also depend on the spoke deisgn of the wheel. if it flares out at all a bit then you might be ok.
The RPM2's was one of my choices. The offset was 35 also. A member has them and it clears the brembos.
Should I believe what discounttiredirect tells me? Do they actually test fit the wheels or measure the TL's brembos and such?
I would think you can believe them. They do have the 6MT seperated vs. the AT 3rd gen TL, so they have differentiated between the two. Your first choice looks like it will need a spacer to fit.
Too bad they don't sell the Enkei ZR-1, I think they are pretty sweet. KBOM has them on his TL and he has 6MT.
1fatcrxnem1
22
06-01-2018 01:23 AM
CLASSYCLS
03-08-2007 02:53 PM
