Eibach springs upside down?
Hi all,
The question I have is if the printed part number on your rear eibach pro-kit springs its right side up, or upside down?
I am thinking I might have them installed incorrectly. let me explain.
I've had eibach pro-kits for my 3G TL for about a year now (with the lettering upside down) and I have had problems with the top 3 coils of the spring which are closer wound to eachother rubbing against one another, causing noise. This was remedied by in the past sliding an included clear rubber looking sleeve up a little higher to prevent the metal on metal sound (and chipping of the powdercoat) caused by this.
Now, a year later the sound is back and bow is it rubbing again! I have moved the sleeve up and down and its not going away. By the way, this is only happening on the rear passenger side wheel. so perhaps the spring is weaker and rubbing more than the other side. In either case, I done see why they would wind the springs so tight as to need this clear rubber sleeve to prevent noise. I think its stupid.
So do I have these installed wrong?
Can anyone with their dead coils on the BOTTOM and lettering right side up please comment on if fitment is correct into the strut perches? I thought that the diameter of the coils at the dead spring coil end of the spring was a different diameter and therefore wouldnt fit into the bottom perch. I guess I can always rip it all back apart but it would be nice to know
![Tongue](https://acurazine.com/forums/images/smilies/tongue.gif)
MrHeeltoe
20
02-23-2023 01:54 PM
emailnatec
29
09-28-2018 04:27 PM
MrHeeltoe
09-29-2015 10:43 PM
MrHeeltoe
09-28-2015 05:43 PM
