eibach and koni or tein basic?
My Konis will be in this week...once I install them with my Eibachs, I'll let you know!
But I expect that the already fantastic ride and handling will be stellar once the Konis are bolted up
Is this koni sp3? http://neuspeed.com/products/product...port&p_id=1935
I have koni sp3's w/ eibachs and the ride is firmer, but nowhere near harsh and feels like the aspec suspension with even less body roll....but im dropped almost 2 full inches compared to .75''
1st TL-S on air in
I love my tein basics even with it all the way on the bottom. The ride is comfortable to me but as far as stock ride i cant even rememeber. I only had 1k on the car when i installed the basics. But i do like the fact that if i need to raise it up for inspections i can do it.
I was also looking at my rear tires when it was up on the hoist getting an oil change....definitely some pronounced inner tire wear, may get a rear camber kit as well.
I know some say that camber kits aren't needed for anything less than a 2" drop but an Ingalls kit is cheaper than tires!
Funny enough I was going to install the Konis today! But I held off as I think I will need a camber kit since I want to drop the fronts down to the lower perch. So it'll be a while yet...but I haven't ridden with SP3s so I can't answer your question. Apparently the SP3s are valved more aggressively than the Sports though...
Im currently running this and have chose to avoid certain roads and dips where I know this will happen.
Take some advice from me and DONT use a camber kit at the moment. Your upper control arms will MURDER the strut tower sheet metal and create big dents when you bottom out because the camber kit's adjustable bolt sits TOO HIGH above the arm. Hold off on it till something comes out which is flush to the top of the upper control arm as Ingall's did later on with the 2G TL. Even on full soft (which allows the most deflection to be put on the shock rather than the upper arm) is still does it on dips and road potholes, even if not extremely severe.
I havent taken any pics yet, but I can. There are others who have talked about this sparatically, but most people with 2'' drops are in Cali and don't have potholes and road imperfections like I do in Ohio, so they are probably not seeing this. Also, a large majority of people never do FRONT camber kits and they just deal with the negative camber for the front as it is less severe (usually -1.5 vs. stock specs of -1). In fact, I'm thinking of removing mine! I'll get those pics up this weekend. There are some other kits out there, but they all have this same design from what Ive seen.
Hmmmm...interesting. I have the Eibach Pro-Kit as well and I just want to drop down a perch in front on the Sports....I suspect about an 1 1/2" in total on the front. From what I've researched, most say a front camber kit is required....but if not, I'd rather avoid buying one. Although I still may get a set for the rear...
Thanks for the info! Christ! Just when you think you have everything worked out, somethin' crops up!lol Well, glad I heard this now rather than later...although I'd rather have no adverse tire wear...tires are f*cking expensive up here!
Love to see pix when you have time to post them!
ITSJESTER
17
12-06-2018 02:29 AM
emailnatec
29
09-28-2018 04:27 PM
