EDFC question
Old 04-23-2008 | 01:54 PM
MaCaY's Avatar
TriState ViP Crew
EDFC question
one of my shock was leaking, i had my shock change but they didnt connect motor from EDFC on that wheel.....when i turn on my car the numbers went up to 8 and error pop out....i conect wire and no more error ,,,but im thinking when i turn off my EDFC and put it back on all motors go up and then down to ''0"...what about this new one isnt in diffrent position now??? or it went all way down too????
Old 04-23-2008 | 02:15 PM
TrevorT's Avatar
Uh oh.
There is a bolt/screw(forget the name) that screws into the top of the strut piston that comes in the EDFC kit package. Do you still have the old strut? You need that piece.
Basically you need to go through the install steps for the EDFC motor for that strut. There is a very detailed installation for attaching each motor. You simply cannot just screw it back on. If you need that page I can scan and e-mail it to you.
Old 04-23-2008 | 02:22 PM
MaCaY's Avatar
TriState ViP Crew
Originally Posted by TrevorT
Uh oh.
i install it goint thru those instructions but after that they dint conect one motor .....do i have to do it one more time????
Old 04-23-2008 | 02:41 PM
TrevorT's Avatar
Sorry I must have misunderstood. The actual motor was installed but the wire was not connected?
If that's the case you should be just fine reconnecting the wire
Old 04-24-2008 | 08:38 AM
MaCaY's Avatar
TriState ViP Crew
yhe i called tein directly and said it will be fine cuz EDFC resets evrytime u turn it on.
ttimberlak443
21
10-22-2016 11:23 PM
navtool.com
3G MDX (2014-2020)
32
01-20-2016 12:43 PM
DerrickW
11-15-2015 06:52 PM
lanechanger
10-13-2015 11:56 AM
Quick Reply: EDFC question
