Does 245/35/19 fit???
I know that some have gone as wide as 255 on 17's and I'm currently running 235/35/19 with no problems but i'm wondering if I can go as wide as 245 and avoid any potential rubbing issues keeping in mind that i'm also dropped. What do you guys think?
re
if you have no camber kit they wont rub but if you install one and align the car to the specs, they will slightly rub on major bumps, id stick with 235's or get 245+ but with a fender roll
'06 750Li Sapphire/Creme
As others have pointed out, it depends on the offset of your wheels (you didn't provide) as well as the mfg of the tire (some are wider than others even at the same 245 width). I have 245/35-19's Falkin 452's on a +30 offset (Private Netz) and they DO rub but ONLY on SIGNIFICANT bumps. Others have different tires and a similar size and do not rub
emailnatec
29
09-28-2018 04:27 PM
calrow
05-03-2017 10:21 PM
