Do I really need to upgrade the front swaybar?
I am sure this has been discussed before, but I would appreciate all opinions and comments as to whether it would make enough of a improvement in handling to justify the cost of the part and the labor to install it
not really what you can do is change if not install an upper strut bar. and either of them can be done diy. take a day to take your time. its not hard at all ive installed sway bars on all kinds of cars. but strut bars will help you can get them for not only the front but the rear as well. but you wont really need the rear.
I'm wondering the same thing too if i need a stiffer front sway bar because my car is oversteering with OEM sway bars front and rear lol.
Why would it not help I don't remember me asking anything about strut bars. I asked about FRONT SWAY BARS
![Annoyed](https://acurazine.com/forums/images/smilies/annoyed.gif)
Registered but harmless
Received 1,106 Likes
For more neutral handling and less understeer, you might consider changing to a stiffer rear sway bar (RSB)-- either one from a manual or Type-S TL (if you're running a 5AT, which has a smaller rear bar) or an aftermarket bar. The RSB is also much easier to install than the front bar.
There are a few threads on RSB changes. However, doing that will also take you out of the "stock" class and into the modified class in autocross, so that you'll have to do even more mods to keep up...
![Chuckle](https://acurazine.com/forums/images/smilies/chuckle.gif)
![Scratch](https://acurazine.com/forums/images/smilies/scratch.gif)
Mine understeers, even with the the rear tires inflated a bit more than the fronts. Oversteer and hanging the rear end out takes some effort on the stock TL.
justnspace (05-26-2013)
our car is made to naturally understeer.(a characteristic of fwd)
Like will Y. mentioned; the goal is to bring the car's handling to a more neutral standpoint.
if car is naturally understeering; what do you think a thicker front sway bar will do?
yes, the answer is MORE UNDERSTEER.
Balance out our natural understeer by adding a thicker sway bar in the rear.
I'm using Progress RSB which is 24mm thick and i have it on the stiffest setting.
I can "lift off over steer" around a corner.
this means I go into a corner at 75% throttle and lift off while in a turn and the back end will swing around
sockr1
10-01-2015 01:31 AM
nuldabz
09-03-2015 05:49 PM
