Do I need an alignment?
I got an alignment 2 months ago because the car was pulling to a side while driving and it was corrected. I just got a new set of tires this week but everything still drives straight with no problems at all. Should I be getting a new alignment again?
2006 TL: WDP/Ebony
not necessary if everything is oK.. So long as no suspension work was done you should be fine. Most places will convince you to get one but since you already got done two mts ago you can wait for a yr or 10k miles
Originally Posted by omnuts
not necessary if everything is oK.. So long as no suspension work was done you should be fine. Most places will convince you to get one but since you already got done two mts ago you can wait for a yr or 10k miles or if you were experiencing odd tire wear on the old tires after the alignment or if you experience odd tire wear in the future.
More amended..
More amended..
emailnatec
29
09-28-2018 04:27 PM
Zonian22
11-14-2015 01:20 PM
